Originally Posted by spokybob
I'm thinking you have it backwards. The new tires are slightly taller so each revolution makes the car go farther. And if you go farther, you must be going faster.
Dude, the speedometer is in a direct relationship with tire revolutions.
Therefore a bigger tire rotates less times in the same distance as a small tire would. That would make the speedometer register less, since the bigger tires are turning less for the same given distance traveled. However, it's a free country and you can "think" however you want, right or wrong, it's your choice.
