Engine swap? Up to the 1.8L? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum
Scion Forum Forum for all Scion models: xA, xB, tC and xD and the new Scion iQ.
Old 05-12-2004, 07:25 PM   #1 (permalink)
View lethal_force's Photo Gallery
I heard a rummor that the toyota 1.8L would be a fairly close swap for the 1.5l in the xB. Has anyone else heard anything about this. The 1.8L would be an obvious bonus and there are alot more turbo and performance options for it. I'v seen the engine bay of the xB and there seems to be plenty of room in there. I wouldn't be surprizes if you could go even bigger.
lethal_force is offline   Reply With Quote
Old 05-13-2004, 11:39 AM   #2 (permalink)
Official Acura Troll
View 02RSX90camry's Photo Gallery
i'm not sure, but i think the mounts are different. I beleive that the mounts for the 1.8L (either ZZ), and the AZ-series are the same though.
02RSX90camry is offline   Reply With Quote
Old 05-13-2004, 02:58 PM   #3 (permalink)
Music nerd?
View Warped's Photo Gallery
The Scions have the 1nzfe, switching to a 1zzfe or a 2zzfe (both 1.8L) would be rather difficult, considering they're both from different engine families.
Warped is offline   Reply With Quote
Old 05-13-2004, 03:28 PM   #4 (permalink)
well starting in june u're gonna hafta say the xA and xB, but yeah, tehy both have the 1NZ.
i can't think of a single car with a NZ and ZZ as options. i'll check teh website later.
Old 05-13-2004, 05:41 PM   #5 (permalink)
very interesting....i didn't think the premio came in a 1NZ trim, i knew it had a 1ZZ, and 1Az, but apparently it also has a 1NZ.
http://www.toyota.co.jp/Showroom/All...grade_val.html
i saw that car when i wa sin india last year, it looks so friggin amazing! i want one soooo bad!
Old 05-24-2004, 05:54 PM   #6 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $231501
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
i would do a 1az swap or a 5vz swap(that would be tight) but it would be a monster
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 05-25-2004, 10:21 AM   #7 (permalink)
The 1az is a 2.0 L right? What is the 5vz? What is a good site to go to to see all the engine codes?
Old 05-25-2004, 12:33 PM   #8 (permalink)
5vz is a 3.4L V6 that comes in trucks. u'd need to convert to rwd to get it to work, not worth it imo.
not sure how big the 1az is, but i don't believe it ever came in teh states, so it'd be easier to find a 2az, and swap that in.
Old 05-25-2004, 01:26 PM   #9 (permalink)
Mad Scientist
the 5vz could be used in a fwd you'd just have to get a shoe horn and some elbow grease or go with the new 3mzfe instead
Camry Wagon Crew
Old 05-25-2004, 01:52 PM   #10 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
um no... if your already having a problem fitting the 2zz-ge with the 6speed in the XB or XA ... Theres no way your going to fit a 3.4Liter V6 into that engine bay without cutting and making a new sub frame. Its going to take more than your elbow grease and your shoe horn...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 05-25-2004, 02:42 PM   #11 (permalink)
I don't think that adding and engine that is another two or three hundered pound is a great Idea anyway. The 2az is a 2.0 L also is it not? What do you think would be a better Ideda anyway: to wait till a good turbo kit comes out or to swap to an engine that already has a turbo?
Old 05-25-2004, 02:52 PM   #12 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
the 2az-fe is a 2.4liter motor found on the New TC and on 5th Gen Camrys... There are some good turbo/supercharger kits out there but they're all having problems converting over... The kits were mocked off the Vitz/Platz in Japan. Which has a 16mb ecu while the 2003 and up XB and XA has a 64mb ecu ... which has alot more tuning required to get it to not go into limp mode, every time the car goes into high load and boost...
MySpace:
Old 05-26-2004, 10:41 AM   #13 (permalink)
u might be thinking of teh 1AZ, that is a 2.0L but never came in teh US
