neo ion for scion stock radio - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum
Scion Forum Forum for all Scion models: xA, xB, tC and xD and the new Scion iQ.
Old 09-07-2004, 01:27 PM   #1 (permalink)
View persyst's Photo Gallery
Question neo ion for scion stock radio
has anyone purchased the
NEO ION for the scion xa/xb/tc single cd stock radio? when i called the neo ion tech support they told me once the neo ion is connected that the "CD" button on the radio should allow you to toggle between the cd player and the ipod. I was wondering if anyone can verify that toggling from first hand knowledge. hit me up, thanks
persyst is offline   Reply With Quote
Old 09-24-2004, 01:43 PM   #2 (permalink)
I just connected my neo ion adapter to my 05 scion tc. it was easy.
step:
1) must have a 3rd,4th gen or mini ipod
2) purchase your neo ion adapter. i got mine from mp3yourcar.com for $189.
2) purchase Toyota harness #08695-00370 from any toyota dealer. i paid $17.
3) stereo removal
1- pull up on the plastic part of the console that surrounds the shift knob. it's a little tough, just grab with both hand both sides of the plastic and just pull up slowly.
2- once you get that out just look for two screws just under the untouched portion of the console.
3- after you take those screws out, you can pull the upper portion of the console out.
4-getting to the back of the radio requires you to remove two screws that are right below the radio unit and the two bolts that connect the radio's frame to the car. The bolts are located in the upper far corners.
4) for connecting the ipod and adapter, just follow all the directions on mp3yourcar.com
-ipod connects to adapter
-adapter connects to large plug on harness
-small plug on harness plugs into back of radio where a cd changer would go (the harness also has an extra input like the one on the back radio. this won't connect to anything)
*i did not disconnect the battery while doing this and there were no problems*
5) use the "Disc" button to toggle between the in-dash single cd player and the ipod
NOTE: when the ipod is selected, while no music playing, there is a slightly audible interference. I called neo ion and was told that interference seemed to occur in some cars and that they will be sending, in about two weeks, all costumers with the various cars, a filter, free of charge, to attach to the adapter, which would eliminate the noise and truly give CD quality sound
The adapter works great otherwise. My filter should arrive next week.
