tire size help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum
Scion Forum Forum for all Scion models: xA, xB, tC and xD and the new Scion iQ.
Old 04-28-2005, 04:44 PM   #1 (permalink)
View slipknot490's Photo Gallery
tire size help
I have been searching online for rims and tires and they say the recommended size tire is 205/40 17" for an xB. I feel that this will provide a rough ride (we are getting the TRD springs and shocks/struts installed) and I may trash the wheels hitting potholes due to the shorter sidewall. Can anyone tell me if this will be an issue and also can I get a 215/45 or 215/50 to fit? Please post some of the sizes you guys are running as it will be very helpful. Thanks in advance.
2004 Matrix XRS
Radiant Red
Strut Tower Brace
A Couple of "Go Faster" TRD Stickers (I swear I can feel the difference)
slipknot490 is offline   Reply With Quote
Old 05-02-2005, 09:33 AM   #2 (permalink)
View boilerman's Photo Gallery
Copied from a post on ScionLife some time ago.
WHEEL FITMENT INFORMATION
It is assumed that these figures will work on both the xA and the xB, but most are from xB owner's personal comments.
WHEEL SIZE . . OFFSET RANGE . . TIRE SIZES . . . COMMENTS
19x8.0 . . . . . . . 40 . . . . . . . . . . . . . 215/35-19 . . . . Rubs under hard cornering
19x7.5 . . . . . . . 45 . . . . . . . . . . . . . 215/35-19 . . . . Rear needs 5mm spacer: DGTLLVR
19x7.0 . . . . . . . 42 . . . . . . . . . . . . . 215/35-19 . . . . Rolled fenders & hammered wheelwell: matchbox
18x7.0 . . . . . . . 28-32 . . . . . . . . . . 215/35-18 . . . .foxSCION "no rubbing"
18x7.0 . . . . . . . 40 . . . . . . . . . . . . . 235/35-18 . . . .K4kas no rubbing
18x7.5 . . . . . . . 35 . . . . . . . . . . . . . 215/35-18 . . . .Front tire rubs at full lock
18x7.5 . . . . . . . 35-42 . . . . . . . . . . 215/35-18 . . . .Silkywilson et42
18x8.0 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x8.5 . . . . . . . 28 . . . . . . . . . . . . . 225/35-18
18x9.0 . . . . . . . 31 . . . . . . . . . . . . . 225/40-18 . . . .rampagesd
17X7.0 . . . . . . . 20 . . . . . . . . . . . . . 205/40R17 . . . .quadoptix xB
17x7.0 . . . . . . . 28-42 . . . . . . . . . . 205/40-17
17x7.0 . . . . . . . 40 . . . . . . . . . . . . . 215/40/17 . . . . .TheScionicMan
17x7.0 . . . . . . . 38 . . . . . . . . . . . . . 215/45-17 . . . . xB stock
17x7.5 . . . . . . . 30-40 . . . . . . . . . . 215/40-17 . . . .
17x7.5 . . . . . . . 40 . . . . . . . . . . . . . 215/40-17 . . . .3mm Spacers CBSIMONSEZ xB
17x7.5 . . . . . . . 38 . . . . . . . . . . . . . 215/40/17 . . . .Stock xA Leinad
17x8.5 . . . . . . . 16 . . . . . . . . . . . . .215/40-17 . . . . Front doesn't rub: Oper8r
17x9.0 . . . . . . . 17 . . . . . . . . . . . . .215/40-17 . . . . Rear rollled fenders: Oper8r
16x7.0 . . . . . . . 33 . . . . . . . . . . . . . 205/55-16 . . . . Front rubs slightly in front: oj411
16x7.0 . . . . . . . . . . . . . . . . . . . . 205/55-16 . . . . No rubs: The Zeeness
16X7.0 . . . . . . . 35 . . . . . . . . . . . . . 205/45-16 . . . . Stock Xb: Pushytop
16x7.0 . . . . . . . 25-35 . . . . . . . . . . 205/40-16
16x7.5 . . . . . . . 38-40 . . . . . . . . . . 215/40-16
15x7.0? . . . . . . 38 . . . . . . . . . . . . . 185/60-15 . . . . Stock Size
15x8.0. . . . . . . 18et rear 23 et front 205/60/15 2" ground control Minsk99 xB
MISC INFORMATION
Scion xA and Scion xB Specifications:
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
15"x5.5" +38 offset / 195/60-15
37 lbs per set
Alloy wheel: 16.7 lbs
Other Vehicles With Interchangable Wheels
Toyota Celica (1988-1989)
Toyota Corolla (1988-2001)
Toyota Corolla Wagon (1988-1996)
Toyota Echo
Toyota MR2 (1986-1990)
Toyota Paseo
Toyota Tercel (1989-1998)
Toyota MR2 Spyder (2000-)
Scion tC Specifications:
Bolt Pattern
5x100
Center Bore
54.1mm
Nut Size
M12x1.5
Stock Wheels/Tires
17"x7.0" +45 offset / 215/45-17
?? lbs per set
(to be added)
boilerman is offline   Reply With Quote
Old 05-03-2005, 05:28 PM   #3 (permalink)
Thanks for the reply. It will be VERY helpful in the near future. I did talk to a tire shop and they said not to go with the 215/45-17 as it is a taller tire (almost an inch difference from the 205/40) and it will put a strain on the drivetrain over time not to mention the immediate difference on the speedometer. Any truth to this? They recommended the 205/40 and said I could go with the 205/45. I know "lo-pro" is cool but I really don't want to worry about potholes as much as I will with the low profile tires.
2004 Matrix XRS
Radiant Red
Strut Tower Brace
Old 12-19-2007, 12:51 PM   #4 (permalink)
Toyota bB "Tribute"
jethro b's Avatar
View jethro b's Photo Gallery
This is an old thread but I feel it needs the proper information.
The correct tire size for a 03'-06' xB in 17" is 215/40/17 not 205/40/17. The 205 according to Tire Rack is under weight rated for the xB and will make the speedo read 3 mph high from not being tall enough.
05' Scion xB Classic in BCP Scikotics/Nashville Chapter
If You Don't Drive a Box... Why Bother?
xB= toaster or box
xB2= neither
jethro b is offline   Reply With Quote
Old 12-19-2007, 03:39 PM   #5 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $163450
View HATEnFATE's Photo Gallery
Good info for those reading..........
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
