LSD Doors allow comfortable access to enter and exit the vehicle with or without lifting the doors to the vertical position.
CELICA 00-05
MR2 90-95
MR2 00-05
LSD HINDGE
The LSD door system consists of a specific door hinge which initially opens the factory door 30 degrees outwards, like a common car door and then upwards by the support of a gas shock with minimal effort.
The door opens in 2 steps:
Step 1: Open the door outwards as usual to a maximum angle of approximately 30 degrees. Allowing comfortable access to enter and exit the vehicle.
Step 2: Lift the door after reaching the opening angle of 30 degrees. This is done with ease as the door is supported by the gas shock to an angle of approximately 40 degrees.
The LSD door hinges are installed at the original mounting points of the dismantled factory hinges. A range of adjustability is built into each LSD door hinge for perfect alignment and operation. Additional features also include limits that prevent the doors from being open too far as well as avoiding contact of the rocker panel. Made in Germany
GO TO NOPI LSD Catalog for model specific details
Contact the salesmen below or PM me for our best deal on LSD Door Kits with Free Freight
