oil fiter wrench or special service tool - Toyota Nation Forum : Toyota Car and Truck Forums
10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum Intake to exhaust, this is the place to discuss what makes 10th Gen Corolla and 2nd Gen Matrix go fast and how it gets there.
post #1 of 19 Old 08-09-2009, 04:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Canada oil fiter wrench or special service tool
can anyone tell me the size of this tool for my 2010 corolla.s. 1.8 engine.
pirate461 is offline
post #2 of 19 Old 08-09-2009, 05:52 PM
jdhog's Avatar
Quoted: 0 Post(s)
65mm 14 flute, or just use a strap wrench they can still work ok.
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
jdhog is offline
post #3 of 19 Old 08-09-2009, 06:09 PM
Scotty61's Avatar
Quoted: 0 Post(s)
Kinda hard to find, ebay or your local NAPA dealer can get you one. Stay away from the combination ones.
...Scotty
Scotty61 is offline
post #4 of 19 Old 08-09-2009, 11:44 PM
Quoted: 0 Post(s)
Originally Posted by Scotty61 View Post
Stay away from the combination ones. Seriously.
Fix'd.
2009 Corolla XRS - 5M
Classic Silver Metallic
FirstXrs is offline
post #5 of 19 Old 08-10-2009, 07:26 PM
jdhog's Avatar
Quoted: 0 Post(s)
here in the US most autoparts stores have them for about $7
jdhog is offline
post #6 of 19 Old 08-11-2009, 12:10 AM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 87 Post(s)
Canada
I bought mine from NAPA for ~$13 total, it was in stock.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline
post #7 of 19 Old 08-17-2009, 02:57 PM
Quoted: 0 Post(s)
I was just wondering if anyone else had the same problem that I did.
The 65mm 14 flute wrench seemed to be too small for my oil filter cap. I couldn't get it to fit over the cap. Was a little too small.
I hoped moving up to the 65/67mm 14 flute combo, although most said it didn't grip well, would be the right size and that was too large. Did what everyone else said and just lost grip every time.
I ended up using a strap wrench because I couldn't get either of the other 2 to work.
Anyone else have this problem or am I just "special"?
Tedo is offline
post #8 of 19 Old 08-17-2009, 03:43 PM
wth
Quoted: 26 Post(s)
Same problem here, as it's a little small & very tight fitting. VERY lightly tapped it partway on and got the filter housing off. I believe mines a KD-3253, but I know I didn't get it from NAPA.
wth is offline
post #9 of 19 Old 08-23-2009, 11:18 AM
Quoted: 0 Post(s)
I had the same problem with a 65mm 14 flute wrendh I bought from Advance Duto -- too tight. I used a strp wrench to remove the filter and took the filer and wrench back tot he store. Advance Auto had another house brand wrench -- 64mm 14 flute that fit perfectly. The tolerance must be very, very small.
Vancerman is offline
post #10 of 19 Old 08-23-2009, 01:19 PM
kevinnz's Avatar
Quoted: 0 Post(s)
i just use my hands.
kevinnz is offline
post #11 of 19 Old 10-27-2009, 07:08 PM
Toyota Addict
Quoted: 0 Post(s)
You said the 65mm was too small and then the 64mm fit. Wouldn't that be a mm smaller? I am trying to figure out exactly what I need to get, but this is very confusing. Anybody came up with an answer or know if you can order them from toyota?
clintj is offline
post #12 of 19 Old 10-27-2009, 08:34 PM
Senior TN Member
Quoted: 5 Post(s)
i have the K-D Tools 3253. at first it was a really snug fit. but after a couple uses it loosened up a lil bit. not sure if im wearing away the the cartridge or what but im not complaining, it works.
pinoyesv6 is offline
post #13 of 19 Old 10-28-2009, 07:38 AM
Quoted: 0 Post(s)
I think the point is that whatever wrench you buy, it may or may not work. People wrote on here that the NAPA wrench worked for them, but I can't comment on that because I never got one. I bought my flutes from a local auto store and one was too small and the next size up was too big. I ended up using a strap wrench and I will continue to do that until that gives me problems. I would recommend using a strap wrench to get it off the first time and if you can get to the store to buy a flute with the cap in hand do that. That is the only way you are going to definitely get a good fit. If you have to purchase a strap wrench in order to do that then I would just continue to use that and don't worry about a flute. There is enough room under there to work with a strap wrench so a flute is not necessary and if you don't get a flute that fits perfectly, you may strip your cap or something like that. Just my opinion.
Tedo is offline
post #14 of 19 Old 10-28-2009, 07:49 AM
2010 Corolla S
Quoted: 0 Post(s)
Funny that this post comes up to the top now. I'm in the process of buying the K-D Tools 3253 from Amazon for my first oil change in this car... Hope it works for me!
Also, I never knew this "cartridge" style filter existed until this car.
TFCommanderBob is offline
post #15 of 19 Old 10-28-2009, 07:53 AM
The random one
Quoted: 1 Post(s)
hah.. neither did I, my father told me he it used to be cartridges in old times... 1970's machinery
kinda annoying having to get a tool to make an oil change.. like if "bring it to the dealer" would be more often, wich come quite expensive for a damn oil change..
MiniPacou is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 10th Gen Corolla/2nd Gen Matrix (2009-2013) > 10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum
User Tag List
Linear Mode Linear Mode
Back
