10w30 oil instead of 0w20 on '09 Corolla LE - Toyota Nation Forum : Toyota Car and Truck Forums
10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum Intake to exhaust, this is the place to discuss what makes 10th Gen Corolla and 2nd Gen Matrix go fast and how it gets there.
post #1 of 12 Old 04-23-2011, 05:45 PM Thread Starter
wei
wei's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Question 10w30 oil instead of 0w20 on '09 Corolla LE
I went to a quick lube place last week and they put in 10w30 without checking with me first. In the engine bay it clearly says use 0w20. Scumbags. My question is, is this bad for my engine? What are the pro/cons that you guys have experienced?
This was at the Xpresslube/Texaco in Midtown Houston (W. Gray Street), by the way.
Thanks.
wei is offline
post #2 of 12 Old 04-23-2011, 06:20 PM
Senior TN Member
joeylgarcia's Avatar
Quoted: 5 Post(s)
omg. if i were you i would sue them.
2009 Corolla S auto Blue Streak Metallic
2014 Corolla S Plus Classic Silver Metallic
joeylgarcia is offline
post #3 of 12 Old 04-23-2011, 06:29 PM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 87 Post(s)
Canada
Reason #26 why you should do the work yourself.
You will be okay for this interval, don't waste the oil. You won't even suffer in fuel economy department either. This has happened to countless 09,10,11 Corollas all over the world and there have been no issues...in fact outside of North America the Corollas have all kinds of oil weight specifications.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline
post #4 of 12 Old 04-23-2011, 07:27 PM
Rob
robfrazr's Avatar
Quoted: 0 Post(s)
Leanburn is right you should be fine the weight difference isnt too dramatic just remember when getting your oil changed somewhere always specify the oil you want to use.
robfrazr is offline
post #5 of 12 Old 04-23-2011, 07:30 PM
Quoted: 3 Post(s)
You live in Texas, they did you a favor.
10W30 will not do anything bad to your engine.
ZO6_Vette is offline
post #6 of 12 Old 04-23-2011, 07:53 PM
Senior TN Member
Quoted: 49 Post(s)
If you are in Canada or anyplace cold then you may have cold start problem.
LE, Smart Key, Limousine tint, Back-up camera and sensor. M.I.C. 7" DVD. Dashcam.
2016 RAV4 XLE Hybrid.
cabur is offline
post #7 of 12 Old 04-23-2011, 08:58 PM
Boy Wonder
ChancreScolex's Avatar
Quoted: 0 Post(s)
iTrader Score: 6 reviews
I would have had them drain it and put the right weight in.
2009 MGM Corolla S - My Garage
Debadged, Hood Dampers, Takeda SRI, 25/15 Tint, LED Dome/Map/License Plate Lights, Weathertech Rain Deflectors, Hella Supertones, Pioneer Premier AVIC-F90BT, 2 12" Pioneer Premier 1200w subs, Magnaflow Exhaust, TRD RSB/FSB/Springs, 18" Enkei EKM3's
ChancreScolex is offline
post #8 of 12 Old 04-24-2011, 03:18 AM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1096 Post(s)
iTrader Score: 8 reviews
+1 The reason I always work on my own car, I know exactly what is going into it. My neighbor had new brakes installed on his 91 Lexus LS400 last week. I saw him working on it this morning & he was replacing the front struts. When I asked him what it was doing I found that the LF caliper was missing both caliper bolts & the RF caliper bolts were only finger tight. Another reason I do the work myself.
+1 They screwed up, make them replace the oil with the proper oil to prove a point. I'm always worried that I would pay for synthetic oil & they would just use the cheap dino oil.
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is online now
post #9 of 12 Old 04-28-2011, 10:18 AM
Quoted: 0 Post(s)
Thicker oil is better for your car. It's not going to hurt it. It will protect better. I live in hot climate (Miami) and drive pretty hard sometimes. I use 10w30 all the time because the oil is thinner in hot climate. I wouldn't use 0w20 if you paid me. You should switch to a heavier grade oil once your car hits 60000 miles anyway
Addition to above entry. I agree with supercharged. Do the work yourself and you have no one to blame for screwing up but yourself. Most shops have apes working on your car.
RedRollaS is offline
post #10 of 12 Old 04-28-2011, 10:29 AM
Boy Wonder
Quoted: 0 Post(s)
"The thinner the oil is, the better it will flow, the less resistance to flow it will have. It will prime and move through the engine quicker. It will carry heat off faster."
I like to think the Toyota engineers knew what they were doing when they stamped 5w-20 on the oil filler cap. Or maybe they just picked an oil weight at random
post #11 of 12 Old 04-28-2011, 10:45 AM
Vivir el momento
Quoted: 34 Post(s)
Setting the record straight.
Agreed. The difference is negligible at best.
Originally Posted by cabur View Post
+1
Incorrect.
I live in a colder part of Canada than you do and I've used 10W30 plenty of times without any cold starting problems. The condition of your car battery is the main factor in cold starting.
Agreed.
A thicker grade of oil will resist burn off more in a hotter climate. Most high mileage formuations of oil are noticeably thicker at full operating temperature since seals tend to age and wear down with time.
Nope. Thinner oil is used for better fuel economy. Thicker oil will protect metals from excess wear better at the expense of some fuel economy.
PhatRoyale is offline
The Following User Says Thank You to PhatRoyale For This Useful Post:
RedRollaS (04-28-2011)
post #12 of 12 Old 04-28-2011, 08:55 PM
Diehard Rams Fan
Engines today are made with much closer tolerances than years ago. Oil is also much better than years ago. Manufacturers use 0w-20 because most engine wear occurs from a cold start up. Thinner oil gets to critical engine parts faster to prevent engine wear. You won't notice any difference in a DD using a 0w-20 vs 10w-30 after the car is warm but there will be more engine wear from cold start up & that wear adds up over the years.
The Following User Says Thank You to SuperchargedMR2 For This Useful Post:
ChancreScolex (04-29-2011)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 10th Gen Corolla/2nd Gen Matrix (2009-2013) > 10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum
User Tag List
Linear Mode Linear Mode
Back
