Engine Light Flashing - Toyota Nation Forum : Toyota Car and Truck Forums
10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum Intake to exhaust, this is the place to discuss what makes 10th Gen Corolla and 2nd Gen Matrix go fast and how it gets there.
post #1 of 15 Old 07-18-2011, 03:49 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Engine light flashing while driving on the highway, loss power, vibration on way to work. After work turn the car on and everything was fine and running again . Any suggestions??
ericgu22 is offline
post #2 of 15 Old 07-18-2011, 04:09 PM
2010 Corolla S
Quoted: 0 Post(s)
A trip to the dealership!
TFCommanderBob is offline
post #3 of 15 Old 07-18-2011, 04:10 PM
2010 Corolla S
Quoted: 0 Post(s)
Stupid fail network....
post #4 of 15 Old 07-18-2011, 06:12 PM
2010 Corolla S
Quoted: 0 Post(s)
Originally Posted by arabianobsession View Post
Okay, calm down. If you waited more than half an hour, you would have gotten an answer. Not everybody is on this site every minute of the day, we all check in when we can.
Personally, I would take a trip to the dealership. If your car is (seemingly?) randomly popping up with a check engine light and you notice a loss of power, followed by normal driving, something is up and should be checked out.
Lol that was me not the OP, and it was a double post failure I'm assuming on the part of my ISP, not TN.
post #5 of 15 Old 07-18-2011, 06:15 PM
Need For Speed
arabianobsession's Avatar
Quoted: 1 Post(s)
Ugh. I'm off today I think, I've had a lot of retarded moments today. I wish you hadn't quoted me, lol.
Sorry for the confusion. Must be the heat. It's 96 here, but it feels like 109 with the heat index. Must be getting to my head.
6 speed manual 2011 Camry SE
1995 Mustang-1994 Mustang GT
1985 AMC Eagle
arabianobsession is offline
post #6 of 15 Old 07-18-2011, 06:36 PM
Senior TN Member
Quoted: 49 Post(s)
Don't think it's your ISP. I'm also having very long delay on mine when I click submit. I'm on cable.
LE, Smart Key, Limousine tint, Back-up camera and sensor. M.I.C. 7" DVD. Dashcam.
2016 RAV4 XLE Hybrid.
cabur is offline
post #7 of 15 Old 07-18-2011, 07:03 PM
Need For Speed
Quoted: 1 Post(s)
^Don't worry, it's an issue that's being discussed with the much higher-ups to see if we can fix it. We're all having a problem.
Sorry for the thread jack, OP!
1985 AMC Eagle
post #8 of 15 Old 07-18-2011, 08:11 PM
KPT
Quoted: 0 Post(s)
Flashing MIL is a misfire. Get the code so you know where to start looking (it will tell you which cylinder).
KPT is offline
post #9 of 15 Old 07-19-2011, 03:55 AM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1097 Post(s)
iTrader Score: 8 reviews
Our high temp was 71 today.
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #10 of 15 Old 07-19-2011, 10:38 AM
Quoted: 0 Post(s)
a check engine light flashing means the engine is misfiring right then as you are driving. Its probably going to show up as P0300, random multiple cylinder misfire. There are lots of possible causes it will need a little bit of investigation work to figure it out.
03 Chevy Silverado 5.3 4x4, tires, body lift, Custom tuning by me
09 Corolla S black
95 Camry 5sfe RIP
all obsessively maintenanced by me
99545 is offline
post #11 of 15 Old 10-03-2011, 02:46 PM
Quoted: 0 Post(s)
Did you get the answer? I have the same problem. I changed the plugs, ignition coils. o2 sensors. Air flow sensor. air filter. Still have the same problem on petrol and LPG.
zwartyvogeltje is offline
post #12 of 15 Old 10-04-2011, 02:43 AM
Diehard Rams Fan
If your CEL is on you need to see what codes the car is throwing before just replacing parts that may not have anything to do with the problem.
post #13 of 15 Old 10-05-2011, 03:42 PM
Quoted: 0 Post(s)
found it. It's the valves that are burned in the head due to the lpg usage. Found this by measuring the compression. Also the o2 sensor was faulty so that needed replacing as well.
post #14 of 15 Old 10-06-2011, 07:37 AM
Quoted: 2 Post(s)
Canada
Which sensor was faulty?? Primary or secondary?
tu_culo is offline
post #15 of 15 Old 10-06-2011, 07:47 PM
Senior TN Member
joeylgarcia's Avatar
Quoted: 5 Post(s)
what year model is your toyota corolla? seems too early to replace parts like o2 sensor.
2009 Corolla S auto Blue Streak Metallic
2014 Corolla S Plus Classic Silver Metallic
joeylgarcia is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 10th Gen Corolla/2nd Gen Matrix (2009-2013) > 10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum
User Tag List
Linear Mode Linear Mode
Back
