Location of Oil Filter Cap-2011 - Toyota Nation Forum : Toyota Car and Truck Forums
10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum Intake to exhaust, this is the place to discuss what makes 10th Gen Corolla and 2nd Gen Matrix go fast and how it gets there.
post #1 of 9 Old 08-01-2011, 12:19 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Need to know where the location of the Oil Filter Cap is on a 2011 Corolla LE?
Any Tips when changing the Filter and cleaning out old residual oil.. This is not a screw on filter.
Crusher66 is offline
post #2 of 9 Old 08-01-2011, 12:23 PM
Senior TN Member
msncorolla422's Avatar
Quoted: 2 Post(s)
to TN first off
here is a diy
1st rolla oil change + pictures
msncorolla422 is offline
The Following User Says Thank You to msncorolla422 For This Useful Post:
atvmaster (08-02-2011)
post #3 of 9 Old 08-01-2011, 07:52 PM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1104 Post(s)
iTrader Score: 8 reviews
to TN & read the above posted thread!
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #4 of 9 Old 08-02-2011, 05:26 AM
The random one
Quoted: 1 Post(s)
Got HIR?
MiniPacou is offline
post #5 of 9 Old 08-03-2011, 12:49 AM
Quoted: 0 Post(s)
Originally Posted by MiniPacou View Post
^^good video !! nice find!
I <3 pinky is offline
post #6 of 9 Old 08-03-2011, 01:23 AM
Senior TN Member
Quoted: 2 Post(s)
him saying type S was really annoying
but it really is a easy job. just look under the car and it should be obvious. and I've never changed oil in a car, but I know how.
but still good find nonetheless
post #7 of 9 Old 08-03-2011, 03:53 AM
Quoted: 5 Post(s)
While I applaud the Youtube DIY video, I have a few comments:
- He says to gently remove the oil filter housing. Yes, be careful and try to avoid having the tool (whichever you choose to use) slip, but you might find the factory (or the last person who changed it) put it on tight. It might take a lot more force than "gentle" to break it loose.
- Likewise, when he puts the filter housing on, he uses a wrench and gives it (what looks like) a strong twist. I recommend very firm hand-tight, or just a very little more with a wrench. Tighter doesn't increase the chance it won't leak. You don't want it to come off by itself, but you might find it nearly impossible to get off next time if you really crank it down.
- When he unscrews the filter housing, he spins it all the way off, spilling oil and missing the collection pan. There are flat spots in the housing threads so if you spin it to certain positions, it will drain quickly and controllably. When it slows or stops, then spin it off the rest of the way.
- Personally, I wipe out the inside of the housing to make sure no debris or grime remains, before putting in the new filter.
- He glosses over changing the o-ring. Change the o-ring before you put the new filter into the housing. Remove the old o-ring and make sure the o-ring channel is clean. Put on the new o-ring and oil it well.
- He noted the new crush washer for the oil pan plug. My original one stuck on the pan (as it did on my 2000 RAV4) and I just reuse it. If you don't over-crush it, and it's not damaged, it won't leak. Or if you like, remove the old one (might require a screwdriver and hammer) and put on the new one. I don't plan to until I see a drip.
2010 Corolla LE
jake111 is offline
post #8 of 9 Old 08-25-2011, 09:06 AM
Quoted: 51 Post(s)
^^ agreed
diablo2184 is offline
post #9 of 9 Old 08-26-2011, 08:15 PM
Quoted: 0 Post(s)
Thanks Toyota, Not!
Looking at the above comments, it would have been SOOOO much simpler if Toyota had simply provided us with a twist-on oil filter. The current situation can be described as "rationalized stupidity."
EWyatt is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 10th Gen Corolla/2nd Gen Matrix (2009-2013) > 10th Gen Corolla/2nd Gen Matrix Engine and Transmission Forum
User Tag List
Linear Mode Linear Mode
« Back
