Engine Control Unit (ECU) parameter changes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009- ) > 10th Gen Engine and Transmission Forum
10th Gen Engine and Transmission Forum Intake to exhaust this is the place to discuss what makes 10th Gen Corolla go and how fast it gets there.
Old 08-16-2008, 11:30 AM   #1 (permalink)
View corolla777's Photo Gallery
There are some changes I would like to see in the ECU. The most important is the target RPM when starting the engine. The RPM surges too high. I can momentarily hear a tapping sound, probably because of oil starvation and high RPM. I would like to have my ECU re-programmed to set the start up RPM lower, so the engine is not raced before the oil circulation is fully established. I think it can be reduced without the engine stalling. Even if it occasionally stalled, that would be preferable to racing the engine during start up.
I think the idle speed (a/c off) could be somewhat lower. That would improve mileage. It could be set lower without stalling the engine. One way the Prius get great mileage is to turn the gas engine off while sitting. The Corolla could come close to this if the idle speed was reduced.
Another change would be to improve the accuracy of the avg mpg calculation. At present, it comes out about 2 mpg too high.
I know it is possible to re-program ECUs. Its been done for more than a decade. I had a 98 Buick which had a problem and the dealership re-programmed the ECU. The change I mentioned can probably be done by changing a single parameter, the target start up rpm.
Does anyone know about Toyota's ECU, history of re-programming (for factory recalls for example) ? Are there any do-it-yourself tools?
corolla777 is offline   Reply With Quote
Old 08-16-2008, 11:54 AM   #2 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $450769
View LeanBurn's Photo Gallery
Canada
I agree, I'd like to see this changes as well. Unfortunately, they do this to warm up the Cat. Converter ASAP to do its job and cut down on emissions.
If you are shocked at what you see at these temps (if this ECU is anything like the 2008's) at -25C and colder the engine surges to 2000rpm and stays there for a while until it warms up!
Until we get this ECU mod what we could do to cut down on wear is use a very good conventional oil at the least, and a semi or full synthetic oil when the temperatures get such to make it idle at 2000rpm.
LeanBurn is offline   Reply With Quote
Old 08-16-2008, 02:31 PM   #3 (permalink)
My celica loves twistys.
blacken's Avatar
View blacken's Photo Gallery
toyota has not been very reprogram friendly as their ecu's are very well programed and locked
there are after market tools but those cost a pretty penny
currently for this gen rolla there are none that i know of
but this gen has been out in the world longer than here
im sure there are tunning tools
they just havent reached our shores yet
or people are keeping them hush hush
Will make proper siggy later.
(RIP) 1992 Black Toyota Paseo (AKA little blacky) (RIP)
2001 Silver Toyota Celica ( AKA - Lady Tiamat- ) (rip)
2009 Silver Toyota Corolla ( AKA - Nonameyet)
blacken is offline   Reply With Quote
Old 08-17-2008, 01:33 PM   #4 (permalink)
joeylgarcia's Avatar
Gameroom cash: $186655
View joeylgarcia's Photo Gallery
i think sfx performance are doing toyota corolla custom ecu programming. just inquire from them. website is: http://www.sfxperformance.com/vehicl...ta-Corolla.asp
joeylgarcia is offline   Reply With Quote
