Keep engine cool when do oil change - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009- ) > 10th Gen Engine and Transmission Forum
10th Gen Engine and Transmission Forum Intake to exhaust this is the place to discuss what makes 10th Gen Corolla go and how fast it gets there.
Old 07-02-2009, 07:51 PM   #16 (permalink)
Corolla Driver
Schroeder64's Avatar
View Schroeder64's Photo Gallery
i change it right when i get back from autozone with my oil so its a bit hot but its fine
http://www.cardomain.com/ride/3875710
CLICK for my CarDomain^^
Schroeder64 is offline   Reply With Quote
Old 07-02-2009, 08:29 PM   #17 (permalink)
OkSlim's Avatar
View OkSlim's Photo Gallery
Originally Posted by johncal View Post
Professionals that recommend warming oil before changing. I couldn't find any that recommended changing it cold. I wanted to go beyond my opinion and see what people that do this for a living had to say. I especially respect the information from Mobil1 and Napa. These are all people with real mechanical and automotive knowledge and experience. Hope this information helps you make the right decision.
http://www.mobiloil.com/USA-English/...ld_Engine.aspx
http://www.napaonline.com/NapaKnowHo.../oilchange.pdf
http://automotive.hardwarestore.com/...motor-oil.aspx
http://www.clarks-garage.com/pdf-manual/eng-17.pdf
http://www.motorists.org/blog/oil-change-essentials/
http://206gti.net/oilchange/
http://www.auto-facts.org/oil-change-tips.html
http://www.lotusespritworld.com/EGui...er_change.html
http://www.usautoparts.net/bmw/repairs/oil_change.htm
http://hubpages.com/hub/How-to-Chang...il--Recycle-It
http://www.mbzponton.org/valueadded/.../oilchange.htm
Don't try to cloud this issue with logic and references
He's rebuilding a jeep for cripes sakes.
OkSlim is offline   Reply With Quote
Old 07-02-2009, 09:42 PM   #18 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $523419
View LeanBurn's Photo Gallery
Canada
Considering the most engine wear occurs at startup, I'll trade my slightly slower colder oil change for less engine wear any day of the week.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 07-03-2009, 08:11 AM   #19 (permalink)
View trucknut1's Photo Gallery
lol, its amazing how easy it is here to stir up the hate, excellent work on the links! ...you have way to much time on your hands! If i remember correctly you were the guy on another thread telling people to clean their paint with gasoline....
please oh please great sage of the links explain to me which method is going to remove the most dirty oil
... you park your car after a drive around town... engine is hot.. car is off, hot oil drips off internal engine components and runs down into the base... car sits there for hours... you then go out and change your oil... that once hot oil has spent hours filling up the base and you drain it out
...or your park the same hot engine, wait 5-10 min and drain the oil... in both cases its hot oil dripping on the internal components of the engine, the car that sat for hours has had far more time to collect the dirty oil in the base then the car that has sat for minutes...
the only difference is that the cooler oil is going to take a few seconds longer to drain from the base
2001 Toyota Tundra TRD
1994 Jeep YJ - no top, no doors May-Oct
1996 Toyota Tacoma - RIP! frame recall $16,638
2009 Toyota Corolla XRS - SOLD
trucknut1 is offline   Reply With Quote
Old 07-06-2009, 12:40 AM   #20 (permalink)
Slow Lane
Inhaled Straw's Avatar
View Inhaled Straw's Photo Gallery
It's best to change motor oil while warm. Flows much easier. Drains quicker.
Change the oil while it's hot (normal engine operating temperature hot) at your own peril. Ignoring the risk of severe burns from the exhaust system, believe me when I tell you that 180F+ motor oil bursting from the oil drain hole down onto your hands and arms (maybe chest and face) is in no way a pleasant experience. Making it worse is when (not if) you whack your head against the car's undercarriage in a frantic panic looking for a rag to wipe the burning oil off your skin.
Inhaled Straw is offline   Reply With Quote
Old 07-06-2009, 06:00 PM   #21 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
Trucknut1:
Experience does not equal common sense.
Warmer temperatures = lower viscosity, plain and simple.
Do or say whatever makes your penis look bigger.
WhiteRabbit is offline   Reply With Quote
Old 07-06-2009, 06:07 PM   #22 (permalink)
TN's furry friend
Your logic is completely flawed, it should be worded as:
Which removes the most dirty oil:
1. A warm engine with free flowing oil left to drain for X minutes, or
2. A cold engine with slow viscous oil left to drain for the same X minutes
The correct answer is obvious, at least to most as it may seem...
But I guess no matter how many times you someone's head, it'll never split because it's super hard. So consider yourself ignored, I don't have the time of day to deal with people who always have to have the last word in. Good luck with your GED someday.
Old 07-06-2009, 07:23 PM   #23 (permalink)
johncal's Avatar
View johncal's Photo Gallery
The guy's like Ralph Cramden. He know's everything and nobody could change his mind.
I agree with you, the vast majority or people and the professionals that do this for a living even though we're all wrong.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 07-06-2009, 08:14 PM   #24 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
Man I could sit here for hours picturing hot and cold oil draining out from an engine wondering how many leetle particles of dirt are flowing and wondering what temperature is best......
I still say hot chocolate temp, but thats mainly cos I work on smaller engines and deisels and I haven't got all day to change the oil.
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
