Originally Posted by JohnO356
You don't remove the large section of dash. Look from underneath and you will see a small plastic section that comes off revealing the fuses. Best way I can think of to describe it is: think of the battery cover on a TV remote, it's similar to that.
I did see that item, 'looking from beneath'. But it seems a fairly impossible task for a
consumer to change a fuse from there. And, as I mentioned, access from that direction is blocked by a substantial cable that would need to be moved out of the way, at least on my vehicle.
