the real size is 205/55R16 Wheel 16x6.5 and offset 39 on my Rolla, but I don't know, what size used better to for my rolla ?:surprise: :help::help::OMG:
which tire 215/45R17 or 225/45R17 ???:bowdown::bowdown:
which wheel 17x7 or 17x7.5 ??? :facepalm::facepalm:
If you are moving up to a 17" wheel and tire than make sure to get a 225/45R17 tire as it's the proper diameter. The 215/45R17 is actually a little small at 24.6" diameter. Every other tire/wheel size is about 25.0" like your 205/55R16. Another option is a 205/50R17 tire too.
As for the wheels I would suggest a 17x8 +35mm offset. Best look and fit without any rubbing issues. Any higher offset or narrower wheel it will look sucked in too much. You can see how mine look with that combination in my signature pic.
Now I got a question for you regarding width of 17 and 18 inch rims... is 9.5 too wide for an 18in rim on a stock height 2013 L?
(as you know I've been saving up for my eventual ROTA GRID R 18x9.5 +38mm offset, mostly because everyone who had gotten the 17's wished theyd just gone up to 18 anyway.)
would a +3 offset on 18's cause problems, or am i better off with the +42 of the 17s? would 9 inch with on 17s, or the 9.5 inch width of 18's cause problems? i don't plan to go below TRD spring height ever, as I do 60 miles on the highway everyday and cant have any rubbing.
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
587K members
Since 2001
