Hello all,
I am trying to replace my aunts 2011 corolla LE drum brakes. I did replace drums brakes on a 97 corolla 12 years ago using the haynes manual. I can't find anywhere information on how to go ahead and change the shoes. I looked at some of the videos but they are different from the ones mentioned on this car.
I started with the driver side drum and tried to screw in the star nut by lifting the lever that holds the gear and I am unable to screw it in to reduce the tension.
Can someone please help me out with the instructions..
Or you are just trying to see how much braking material you have left?
I assume the Corolla brakes are like the ones I have on my Camry. There is a little tab on the thing that holds the star gear. Try to insert a little screwdriver towards the rear end and push on it. It should release the tab and you will be able to rotate that gear.
So I just removed all the brake dust and I was able to to screw in and move the star brake adjustor , which was initially hard to move.
I put the drum back and drove in to work... no squeak sounds anymore .. the shoes did have 50% of life. All this while I thought it needed new brakes. It's probably the combination of the brake dust and the hard to move star adjustor...
I will still need to info when it's time to change ... probably 6-7 months from now ( fingers crossed )
