Originally Posted by cwayne
I totally agree that they charge too much for the new Corollas that offer very little. Even some of the competition has a fully IRS on their cars that are CHEAPER than the Corolla.
Your suspension system shouldn't break unless you try to drive your Corolla like the Dukes of Hazzard. Shocks and joints replacement is normal wear and tear for every car.
The Civic also achieves all that, including a TRUE sport.
That's the problem with the new Corolla, it isn't "low-priced".
Too much for new Corollas? If you compare equipment, the Corolla is cheaper than a Civic. It sounds like you're only concerned about sport and not much else. The Corolla then is not really for you. The Corolla is the most refined car in the segment, and if you want some sport *with* the refinement than that is what the XRS is for.
I never said anything about broken suspension. My point was that when it comes time to replace your suspension pieces (due to normal wear and tear) a Corolla WILL be cheaper than a Civic. The current Civic by the way has a double wishbone rear suspension. Over the long-term, with wear-and-tear replacements the Corolla will end up being cheaper with it's simple torsion beam setup compared to the Civic's more complex double wishbone setup.
Like I said earlier, the *top* priorities for the Corolla have always been reliability, low maintenance, and also comfort and refinement. These have NOT been top priorities for the Civic. The Civic is more sporty, but it will cost more over the long term for maintenance, and the Civic is also less refined than the Corolla. The Civic will also likely have higher insurance since Civics are high-theft cars and Corollas are not.
I don't see how we're getting "less" with the new Corolla. In the US, for the same cost as the old model, you're getting MORE standard equipment, better fit and finish, and a better base engine. In Canada, the new Corolla is cheaper than the old model.
