2 bolts on front caliper brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009- ) > 10th Gen Suspension, Brakes and Wheel Forum
10th Gen Suspension, Brakes and Wheel Forum Slam. Poke. Drop. Tuck. STOP. A forum to discuss 10th generation Corolla suspension, brakes and wheels even if you're rollin' OEM.
Old 08-13-2008, 01:40 AM   #1 (permalink)
joeylgarcia's Avatar
Gameroom cash: $186655
View joeylgarcia's Photo Gallery
Canada 2 bolts on front caliper brakes
correct me if i am wrong but without the tires mounted on the front i could feel and see that there are 2 bolts holding onto the front caliper brakes. just in case i want to remove those front calipers from being mounted, is it ok to remove those 2 bolts and not damage or alter the brakes and its function? i wanna remove them so that i can paint them neatly. i am worried i might alter or damage the caliper functionality in case i remove those 2 bolts.
oh man doing small things on the 09 corolla without the repair manual is really a challenge.
joeylgarcia is offline   Reply With Quote
Old 08-13-2008, 03:20 AM   #2 (permalink)
CRT > LCD
ZenithTheTV's Avatar
Gameroom cash: $220582
View ZenithTheTV's Photo Gallery
The calipers are of the same design as the 9th gen's brakes which are a similar design to the other toyotas.
If you're going to paint the calipers, you will need to remove those bolts and the brake line connection. If you havent done anything like it before, I'd recommend against doing it on your own since they are sort of important when stopping the car.
ZenithTheTV is offline   Reply With Quote
Old 08-13-2008, 10:35 AM   #3 (permalink)
what if i just remove the 2 bolts just to unmount the caliper brakes and not disconnect the brake line connection? is that ok too?
Old 08-13-2008, 05:52 PM   #4 (permalink)
Gameroom cash: $421887
View cabur's Photo Gallery
Aren't your front calipers cadmium plated? That silver colour?
If you do not disconnet the brake line the caliper can only swing out and not totally removed. Be very care though you'll have to bleed the line if you disconnet it. Also '09's have ABS and EBD. 08's don't.
cabur is offline   Reply With Quote
Old 08-13-2008, 06:30 PM   #5 (permalink)
yes the front calipers have that silver color. bleeding the brake line to install back the brake calipers is one thing i want to avoid. ill find out if i can paint them by just swinging out the brake calipers. thanks.
Old 08-13-2008, 07:45 PM   #6 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $383212
View Jeff Lange's Photo Gallery
Clamp the hoses when you remove them, bleeding them is easy. I don't understand the problem?
Pull the calipers off, paint them, throw them back on, bleed the brakes, easy as pie.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 08-13-2008, 08:09 PM   #7 (permalink)
NIKKICHICK's Avatar
View NIKKICHICK's Photo Gallery
Jeff
Some folks can't make pie
NIKKICHICK is offline   Reply With Quote
Old 08-14-2008, 02:09 AM   #8 (permalink)
CRT > LCD
If you dont' fully remove the caliper while painting, you have to take extra care that overspray doesn't hit your pads or your rotors. Even if its just a little bit that you can't see could compromise your braking ability later on.
As for the calipers being cadmium plated, it means that any paint that will stick to them will require quite a significant amount of spraying, so I really don't see how you're going to be able to do it with the calipers still mounted.
Old 08-14-2008, 10:09 AM   #9 (permalink)
Jeff Lange's Avatar
Oh, I meant it was as easy as eating pie. Most people can do that.
LOL.
Pie.
Jeff
Old 08-14-2008, 01:27 PM   #10 (permalink)
so what is a good caliper brake cleaner?
Old 08-14-2008, 05:18 PM   #11 (permalink)
toyotaQC's Avatar
View toyotaQC's Photo Gallery
Canada
I used the brush on red tremclad paint. That way I didn't need to remove the calipers. I painted the calipers on my xrs nearly three months ago and they still look great. The tremclad has a deeper red than most caliper paint and costs less. As far as durability goes, I painted one of my cars calipers and it still looked good 5 years later when I sold it.
toyotaQC is offline   Reply With Quote
