What is the typical tire pressure of 2009 rolla - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009- ) > 10th Gen Suspension, Brakes and Wheel Forum
10th Gen Suspension, Brakes and Wheel Forum Slam. Poke. Drop. Tuck. STOP. A forum to discuss 10th generation Corolla suspension, brakes and wheels even if you're rollin' OEM.
Old 07-13-2009, 08:06 PM   #16 (permalink)
View goodman's Photo Gallery
Canada
Every one has their preference on desired pressure other than the one in the manual.
goodman is offline   Reply With Quote
Old 07-13-2009, 08:28 PM   #17 (permalink)
johncal's Avatar
View johncal's Photo Gallery
A "few" have a desired tire pressure, but you asked what the "typical" tire pressure is. Typically, people use the recommended pressure. The only time you should consider varying from that is if you notice excessive center or edge wear on your tires, or if you use non-factory sizing. Even at that, many non-factory sizes run and wear perfectly at the factory pressure. I run 225-40-18's on mine and they wear perfectly at 32psi.
My recommendation would be to check wear and adjust accordingly. If the edges are wearing faster than the center, bump the pressure up a couple of lbs. If the center is wearing faster, drop it a couple. Sometimes people that drive aggressively and ride a lot of twisty roads will wear the edges faster.
No one here can give you a best answer other than "factory recommended" because some people drive differently, carry crap in their trunks all the time, or have allignment issues.
Regular rotation and allignment checks are the best way to keep your tires good along with checking the pressure at least once a month.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 07-31-2009, 03:55 PM   #18 (permalink)
View corollasport09's Photo Gallery
correct! I keep mine at 34 PSI and never had a problem. Just rotated the tires myself yesterday
corollasport09 is offline   Reply With Quote
