What is the typical tire pressure of 2009 rolla - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009- ) > 10th Gen Suspension, Brakes and Wheel Forum
10th Gen Suspension, Brakes and Wheel Forum Slam. Poke. Drop. Tuck. STOP. A forum to discuss 10th generation Corolla suspension, brakes and wheels even if you're rollin' OEM.
Old 07-07-2009, 03:25 AM   #1 (permalink)
View goodman's Photo Gallery
Canada What is the typical tire pressure of 2009 rolla
My dealer likes to keep 35psi, but the manual recommend 32. What is the optimal pressure to balance the tire wear out and gas consumption?
goodman is offline   Reply With Quote
Old 07-07-2009, 07:39 AM   #2 (permalink)
Ask your Mother
sinnaever's Avatar
Gameroom cash: $242734
View sinnaever's Photo Gallery
Please use the Search function...
MANY threads about this...
*Closed*.... as soon as a Mod stumbles on this...
2009 Corolla XRS
2006 Matrix XR
sinnaever is offline   Reply With Quote
Old 07-08-2009, 05:37 PM   #3 (permalink)
View FirstXrs's Photo Gallery
Actually, I can only recall ONE thread where someone asked what tire pressure they ran with.
To answer the question, I have no idea. It would depend on when/where/how you drive, the weather, how fast you are traveling, and how heavy your car is.
I personally roll with 32 psi. Not sure why, but I like the number 32.
2009 Corolla XRS - 5M
Classic Silver Metallic
FirstXrs is offline   Reply With Quote
Old 07-08-2009, 06:23 PM   #4 (permalink)
johncal's Avatar
View johncal's Photo Gallery
What the manual says and Tire Rack agrees. They even recommended the same pressure when I went to 225/40-18's because the air chamber for that profile tire is the same size and they tested it with good results. Rides great and my wear is very good, so I would tend to think they're right in their recommendations.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 07-08-2009, 07:15 PM   #5 (permalink)
View bydotte's Photo Gallery
me too, maybe b/c of magic johnson? it's shaq's # too but i think i liked it before he came along
bydotte is offline   Reply With Quote
Old 07-08-2009, 10:20 PM   #6 (permalink)
I believe when the dealer checked my tire pressure, they actually lifted the car. The tire pressure was measured without consideration of the car's self weight. When I did the measure, it included the car's weight.
Although possibly we both measured by 32 psi, the actual tire pressure was higher without consideration of the car's weight.
Conclusion:
If your dealer check the tire pressure during tire rotation, make sure you check it again with the car on the floor.
Old 07-08-2009, 11:16 PM   #7 (permalink)
View jkowalski's Photo Gallery
Tire pressure doesn't change if the car is off the ground, or on the ground. 32PSI is 32PSI.
2009 Corolla S, 5 speed manual, power moonroof, "sport package," VSC.
jkowalski is offline   Reply With Quote
Old 07-09-2009, 12:09 AM   #8 (permalink)
on full afterburner
PhatRoyale's Avatar
Gameroom cash: $1191747
Old 07-09-2009, 12:26 AM   #9 (permalink)
Canada
I think off ground or on the ground matters. Just like a balloon, if you press it, the internal pressure should increase to again the the pressure from outside.
Old 07-09-2009, 12:29 AM   #10 (permalink)
on full afterburner
PhatRoyale's Avatar
I've never heard of that method of measuring tire pressures before.
But I do know that it's important to take your tire pressure readings when they are cold, or have been sitting overnight to ensure the best possible accuracy.
Old 07-09-2009, 06:32 AM   #11 (permalink)
They say the reason it doesn't matter is how the tire kind of bows-out at the bottom when you lower the vehicle. For that reason, the internal dimensions of the tire doesn't really change, which obviously, pressure is totally related to the area that it has to fill up.
I know this is true because on aircraft I work on (which weight in at 120,000 pounds), the pressure doesn't really change on them either.
Old 07-10-2009, 02:01 PM   #12 (permalink)
Canada
See dealer again. You're right. It doesn't matter if the car is lifted or not. The tire pressure should be constant at 32 psi.
Old 07-13-2009, 01:48 PM   #13 (permalink)
View Jim Bob Jones's Photo Gallery
Also depends on the tire that came on the vehicle. I always run a little higher than the manual recommends but less than the pressure max on the sidewall. I find gas mileage and response improve. Increased tire wear has been neglible in my experience.
Jim Bob Jones is offline   Reply With Quote
Old 07-13-2009, 06:59 PM   #14 (permalink)
OkSlim's Avatar
View OkSlim's Photo Gallery
Mine is on a sticker on the door jam.
OkSlim is offline   Reply With Quote
Old 07-13-2009, 09:03 PM   #15 (permalink)
johncal's Avatar
Why would anyone look there? They could check the manual, but (see first comment)
