Tire Pressure? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix Suspension, Brakes and Wheel Forum Slam. Poke. Drop. Tuck. STOP. A forum to discuss 10th Gen Corolla and 2nd Gen Matrix suspension, brakes and wheels even if you're rollin' OEM.
post #1 of 12 Old 07-27-2008, 01:47 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Tire Pressure?
What is the maximum tire pressure permitted on the Toyota tires? and if the tire pressure is increased, will this effect the tire sensor located on the rim, could it malfunction? or cause a "Check Engine Light" to activate?
any information would be appreciated
lonejedi is offline
post #2 of 12 Old 07-27-2008, 02:32 AM
09 corolla xrs
Quoted: 0 Post(s)
your corolla manual will tell u , go check it out,
plus, u don't need maximum tire pressure, u just need a correct pressure
for xrs, 17" wheel +tire, is 32psi
rCustom is offline
post #3 of 12 Old 07-27-2008, 09:15 AM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 93 Post(s)
Canada
From what I can tell, the TPMS are calibrated at eg 32psi and work by checking to make sure the pressure doesn't go any lower than this setting. It doesn't 'care' if it goes higher as tires don't increase in pressure on their own. Due to ambient temperature fluctuations, tires can lose pressure. We have to adjust our pressure in every season change due to the temperature variations.
LeanBurn is offline
post #4 of 12 Old 07-27-2008, 05:12 PM
Owner of much Obsolete
Jeff Lange's Avatar
Quoted: 7 Post(s)
TPMS are calibrated to whatever you want them to be at when you press the Tire Pressure Set button.
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
1993 Toyota Previa 5MT Studded Ice Race Van
Jeff Lange is offline
post #5 of 12 Old 07-27-2008, 06:03 PM
Quoted: 0 Post(s)
amen brotha
max2evoix is offline
post #6 of 12 Old 07-27-2008, 07:22 PM
Quoted: 0 Post(s)
Max cold inflation pressures are molded into the sidewall of the tire. IIRC they're 44 PSI for the Corolla. Why you'd want to drive with such high tire pressures is beyond me.
Keith DC5 is offline
post #7 of 12 Old 07-28-2008, 03:11 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Red face
See living here in Hawaii, There is no Snow, No heavy Rains tha'll flood, only nice clear skies, with the slight chance of a hurricane, rainbows in the day a & peaceful nights, and the ever increasing prices of gas, increasing pressure to the 10lbs higher limit will increase mileage..................then save gas...........then improve expenses.............an so forth, i had tires pressured at 32 psi, then you know what? had to change them because of improper wear, that with rotation, maitain pressure and everything you could think of and so forth, got other tires that had to replace them they put in the air pressure set @ 45 psi & got 5mpg more for the buck.......so go figure.....as for me learned from experience, got any other interesting comments?
lonejedi is offline
post #8 of 12 Old 07-28-2008, 09:09 AM
Senior TN Member
joeylgarcia's Avatar
Quoted: 5 Post(s)
i have to agree on that regarding higher air tire pressure. wear and tear on the tire during "normal" driving is less or should i say the tire life is longer when you are on a higher air tire pressure. the only drawback is the ride becomes more bouncy than when you are on the factory specified air tire pressure.
joeylgarcia is offline
post #9 of 12 Old 07-29-2008, 06:59 AM
Quoted: 0 Post(s)
says the guy who needed help finding the max inflation pressures. Don't be so cocky when people are helping you out, esp. if they're far more familiar with cars than you are.
If your previous tires were set at the factory recommended levels and you experienced uneven tread wear, that's a vehicle load or alignment problem. If you haven't noticed, most of Hawaii roads are tapered (road crowns). What you obviously overlooked is that overinflated tires can still cause uneven tread wear not to mention the decreased contact patch reduces lateral grip, increased stopping distances, etc.
Factory recommended inflation levels are a compromise between ride quality, vehicle performance, efficiency, and longevity. You can adjust them to your needs accordingly but I'm sure you knew that since you're so experienced.
post #10 of 12 Old 07-29-2008, 07:57 AM
Glock Perfection
nam6869usmc's Avatar
Quoted: 0 Post(s)
Checked my Goodyeay Eagle LS-2 195-65-15's stock tires & they had 45psi all the way around....51psi is max.
USMC 0311 - 1811 RVN (Dec 67 - Aug 69) I-Corp DMZ "Leatherneck square"
nam6869usmc is offline
post #11 of 12 Old 07-29-2008, 10:29 AM
Quoted: 0 Post(s)
TPMS only pops up a warning when there is over a 4psi difference between tires. In other words, if all 4 had only 20 psi, no warning. If all 4 are at 50 psi, no warning. If front two are at 32 and rears are at 26 psi, you get a warning. It is designed for signalling a warning for a singe tire going flat, which is more prone to cause a dangerous condition. This is what a Toyota master service tech told me.
'05 Silver Tacoma Double Cab 4x4 TRD Sport - sold 4/5/08
'09 Classic Silver Metallic Corolla S GEN X - sold 3/27/2009
'08 Classic Silver Camry SE V6 GEN 6
Big05Taco is offline
post #12 of 12 Old 07-29-2008, 06:49 PM
LeanBurn's Avatar
Quoted: 93 Post(s)
Canada
Good to know, thanks.
LeanBurn is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013) > Corolla 10th Gen/2nd Gen Matrix Suspension, Brakes and Wheel Forum
User Tag List
Linear Mode Linear Mode
Back
