09 Corolla Wheel Nut torque!! - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix Suspension, Brakes and Wheel Forum Slam. Poke. Drop. Tuck. STOP. A forum to discuss 10th Gen Corolla and 2nd Gen Matrix suspension, brakes and wheels even if you're rollin' OEM.
post #1 of 14 Old 02-19-2010, 09:59 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Where would I be able to find the Wheel nut torque for 09 Corolla and the caliper nut torque? Planning on changing the brakes but don't know the specs or just tighten until I feel its tight?? Thanks
ericgu22 is offline
post #2 of 14 Old 02-19-2010, 10:04 PM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1132 Post(s)
iTrader Score: 8 reviews
Wheel lug nut torque is 76 ft/lb. I'm not sure about the caliper bolts. A quick call to a dealer would be able to get you that number.
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #3 of 14 Old 02-19-2010, 10:57 PM
straight cash homie
got-rice's Avatar
Quoted: 2326 Post(s)
yup...76 ft. lbs. is pretty standard for all Toyotas. Hand tight should be fine (12 ft. lb. or something) for the brake caliper bolts, as that's what I've seen when I used to work at the dealer.
got-rice is offline
post #4 of 14 Old 02-20-2010, 01:29 AM
TN Stalker
ekimnal's Avatar
Quoted: 26 Post(s)
yeah... don't go too much over.. or else what happened to me might happen to you
-Mike
2010 Blue Corolla S MT
ekimnal is offline
post #5 of 14 Old 02-20-2010, 09:00 AM
OkSlim's Avatar
Quoted: 2 Post(s)
He will become Pedobear?
The Blue Streak Slug
2008 Tundra TRD Offroad
OkSlim is offline
post #6 of 14 Old 02-20-2010, 10:49 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Another Question, How would I be able to adjust the hand brake cable on the Rear Drums??
ericgu22 is offline
post #7 of 14 Old 02-20-2010, 11:19 AM
TN Stalker
ekimnal's Avatar
Quoted: 26 Post(s)
HA! i wish...
but unfortunately, the actual end result will be this:
I'm super strong!!!
it was a pain in the ass...
-Mike
ekimnal is offline
post #8 of 14 Old 02-20-2010, 01:08 PM
Owner of much Obsolete
Jeff Lange's Avatar
Quoted: 7 Post(s)
Wheel Lug Nuts: 76 ft-lbs
Caliper to Bracket Sliders: 25 ft-lbs
Caliper Bracket to Knuckle: 79 ft-lbs
Jeff
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
1993 Toyota Previa 5MT Studded Ice Race Van
Jeff Lange is offline
post #9 of 14 Old 02-21-2010, 09:29 AM
johncal's Avatar
Quoted: 0 Post(s)
You really shouldn't recommend something if you don't know the answer FOR SURE! You could cause somebody to get hurt - or in the case of brakes much worse!. Jeff had the correct answer and what you recommended for the caliper bolts was only HALF the recommended torque, very dangerous.
I found the right info on GOOGLE on only the third site I checked. You guys really ought to try searching outside of this forum once in a while.
Be careful not to follow critical advice on what people "THINK".
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline
post #10 of 14 Old 02-21-2010, 11:11 AM
Quoted: 0 Post(s)
Adjusting the parking brake:
Toyota specs are: after setting the parking brake, release it. Than, apply it again. It should "click" 6-9 times at 200N (20kgf, 45.0lb-ft)
Here is the text of how to adjust it:
-Remove upper console box assembly
-Completely release parking brake lever
-Loosen lock nut and the adjusting nut to completely release parking brake cable
-Fully depress brake lever 3-5 times with the engine stopped
-Turn adjusting nut until the parking brake lever travel is corrected to within specified range
-Using a wrench, hold adjusting nut and tighten the lock nut: 6.0 N*m (61 kgf*cm, 53 in*lbs)
-Operate parking brake lever 3-4 times, and check lever travel
-Check whether parking brake drags or not
-Install upper console box assembly
2009 Corolla S, 5 speed manual, power moonroof, "sport package," VSC.
jkowalski is offline
post #11 of 14 Old 02-22-2010, 04:25 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Is this for the Rear Drum brakes or disc or you have to take the Rear Drum Brakes off to adjust it?
ericgu22 is offline
post #12 of 14 Old 02-23-2010, 07:56 AM
Quoted: 0 Post(s)
I believe the above instructions are for adjusting the travel distance of the handbrake cable so that when you pull on the handbrake handle, sufficient tension on the cable (hence applying pressure on the rear brakes) is achieved within 6-9 clicks. If the cable is too loose, you will pull on the handle and it will travel all the way to the end without applying sufficient tension on the cable. On the other hand, if the cable is too tight, you risk applying a pre-tension to the cable which can cause the rear brakes to wear prematurely.
The above instructions say to remove the upper console (behind the handbrake) to expose the handbrake adjustment nuts. You will see the adjustment nuts once you remove the console: there is one adjusting nut and a lock nut to adjust the travel distance of the handbrake cable.
You don't need to remove the rear wheels nor the rear drums at anytime.
Have you ever adjusted your bicycle brakes by adjusting the nut around the brake cable that goes to the brake handle? that is the same idea here
If adjusting the handbrake cable does not succeed, you can check if the clearance between the shoes and the drums is correct by turning the star wheel cog in the rear brakes. Normally you don't need to adjust the star cog wheel unless you service the brakes.
hungt1999 is offline
post #13 of 14 Old 02-23-2010, 11:01 AM
straight cash homie
got-rice's Avatar
OK, I was wrong on the caliper bolts...pardon me.
got-rice is offline
post #14 of 14 Old 02-23-2010, 09:39 PM
Banned
Quoted: 0 Post(s)
yellow pages for local dealer service dept is also a good source.
TACO_KID is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013) > Corolla 10th Gen/2nd Gen Matrix Suspension, Brakes and Wheel Forum
User Tag List
Linear Mode Linear Mode
Back
