225/50/16 on 6.5" rims GOT PICTURES? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix Suspension, Brakes and Wheel Forum Slam. Poke. Drop. Tuck. STOP. A forum to discuss 10th Gen Corolla and 2nd Gen Matrix suspension, brakes and wheels even if you're rollin' OEM.
post #1 of 14 Old 01-04-2011, 10:54 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Here's the deal. I have a 2009 Corolla S with the stock 16" wheels. I really like them. These are 6.5" wide. Stock tire is 205/55/16. I am looking to put 225/50/16 tires on it. My brother works at a wheel shop and I get 50% off. Woo hoo!
Right now I have stock shocks and springs. After tax time I am going to lower it with the TRD springs and bilstein shocks. Do you have suggestions? Has anybody done this? Do you have pictures?
RedRollaS is offline
post #2 of 14 Old 01-04-2011, 01:36 PM
Dimaoala's Avatar
Quoted: 2 Post(s)
Best to use a tire size calculator if you don't know how
Heres a link: http://www.1010tires.com/tiresizecalculator.asp
I see your going to go with TRD Springs, they give a mild drop if thats what you want. IMO TRD drop is suppose to look like how the Corollas should of have came like factory.
I recently installed Tein H-Tech Springs (9thGen Corolla Springs) and I sure do love the drop, great as a DD as well.
Dim's 2009 Super White Toyota Corolla XRS Turbo!
Dimaoala is offline
post #3 of 14 Old 01-04-2011, 03:31 PM
Quoted: 0 Post(s)
that's a hot ride! props
2004 Toyota Solara SLE
ll CP-e Intake ll TRD Lowered ll TRD Exhaust ll TRD RSB ll 20/5 Tints ll Custom Grille ll Alpine Headunit ll Rocksford Fosgate Amp ll 2 10" JBL Subs ll 6000k HID ll Satisfied Driver ll
http://i67.photobucket.com/albums/h292/yaddadaimsayin/banner1.jpg
YADDADAIMSAYIN is offline
post #4 of 14 Old 01-23-2011, 05:30 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the tire calculator. I think I am just going to stick with a high performance tire in the size that the rim was supposed have. That size tire really needs a wider rim. You can do that with a truck tire that has some size but with a car tire I'll just end up with tires that are not worn properly since they are not touching the ground even. Nice ride!
post #5 of 14 Old 01-23-2011, 06:29 PM
Vivir el momento
Quoted: 34 Post(s)
That is the least of your worries.
With that kind of upsizing there is a risk of the tire unseating itself or excess heat buildup in the sidewalls at highway speeds will even have a possibility of a tire blowout.
PhatRoyale is offline
post #6 of 14 Old 01-23-2011, 06:34 PM
Owner of much Obsolete
Jeff Lange's Avatar
Quoted: 7 Post(s)
225/50R16 would work fine on the stock wheels, and is within tire manufacturers recommendations for wheel width (6.5").
I would have no problem running that size.
Jeff
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
1993 Toyota Previa 5MT Studded Ice Race Van
Jeff Lange is offline
post #7 of 14 Old 01-25-2011, 12:36 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA
In truth the tire would fit and work on it and probably not have any serious issues as we can do a lot of mechanically unsound things with tires. But, I agree I think safety wise the tire would be at much more risk of unseating itself as it bulges too far away from the rim. Heat probably not so much as the way I drive my car I usually baby it. The tire would for sure wear out improperly because it isn't making proper contact with the road again this is caused by the same problem that puts it at risk of unseating. Thanks have a great day!
post #8 of 14 Old 01-26-2011, 01:10 AM
Jeff Lange's Avatar
Quoted: 7 Post(s)
While putting a tire too wide on can definitely cause issues, a 225/50R16 on a 6.5" wheel is recommended. You won't have odd wear or unseating. It's a good fit.
Jeff
post #9 of 14 Old 01-26-2011, 01:28 AM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1245 Post(s)
iTrader Score: 8 reviews
Jeff
It's funny how people don't seem to understand this fact.
89 Supercharged White MR2 MT/09 Corolla S TURBO CSM MT
95 Previa S/C White AT/06 Scion xB MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #10 of 14 Old 01-26-2011, 07:03 AM
Vivir el momento
Quoted: 34 Post(s)
Jeff
It seems as though there are two prevailing schools of thought on the issue here.
The final answer seems to be that it depends on which tire you're choosing. While most tires in a 225/50/16 sizing call for a 6-8" wide wheel, there are others that call for a 7-9" wheel, which in that case a 6.5" wheel would not fit.
If it did call for a 6-8" it would be fine to run a 6.5" wheel. But handling ability is to be debated. I personally would go for a wheel that is toward the 8" side of the spectrum in order to prevent excessive sidewall flex. But that's just me.
post #11 of 14 Old 01-26-2011, 12:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
The tires I chose are "wider" compared to other tires of the same size if you know what I mean. I think if I had chosen a "skinnier" tire it would have looked ok. In the end I chose to go with a stock tire and I'm actually pretty happy b/c they are very grippy. Right now I am spending money on chassis stiffening and a set of TRD springs and Bilstein shocks. I am going to save up for a set of TRD rims and put them on when this set of tires wear out. Thanks to everyone for their input it's appreciated.
post #12 of 14 Old 01-26-2011, 08:35 PM
Jeff Lange's Avatar
Quoted: 7 Post(s)
I also agree with you, I prefer a wider wheel and a more square tire fit, but in this case, if he wants to run a 225, I don't think there is a point discouraging it.
Jeff
post #13 of 14 Old 01-27-2011, 01:37 AM
Diehard Rams Fan
Jeff
+1
I myself have 225/45R17 tires on 8" rims but the 6.5" wheel would work okay. I was in the tire business for many years & that was never an issue & still shows as an acceptable wheel size for the width of the tire.
The Following User Says Thank You to SuperchargedMR2 For This Useful Post:
T.Holla (01-06-2014)
post #14 of 14 Old 01-27-2011, 07:07 AM
The random one
Quoted: 1 Post(s)
225/45/17 on 7in @ 33psi
different angle stock springs
look at the front tire you will see the sidewall better
Got HIR?
MiniPacou is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013) > Corolla 10th Gen/2nd Gen Matrix Suspension, Brakes and Wheel Forum
User Tag List
Linear Mode Linear Mode
Back
