Originally Posted by joeylgarcia
if u will be receiving the item that is in the picture im pretty sure that will fit. only the 10th gen corolla tail lights are shaped that way.
I hate to be argumentative... however, I'm more than "pretty sure" that they wont fit. Look at the MARS photo... and then scroll up in this thread to the pics water-marked "revotec" (up about 12 or 13 posts, and also in the OP). and compare the two models.
Notice that the Revotec ones are contoured for flush fit against the body of the car. The Mars ones have that extra piece sticking out of the back
The Revotec ones are the identical tail lights I JUST installed only a few days ago -- and you wont see that same piece sticking out the back-view of the revotec pic, like you do on that of the MARS model: and for good reason... because whatever that piece is jutting out from the back of the MARS model will pretty much guarantee that they WON'T fit properly on a 10th-gen Corolla.
It doesnt matter what the shape the perimiter of the lenses are... or what years the 10th gen design came out in other countries... fact remains that if that piece does in fact exist on the back of the MARS model, then it wont fit on the car. There's no hole in the body for that piece to insert into -- at least not on the North American model.
The Mars site is priced in Australian dollars, so it's quite possible they are for Eastern models... which might be the difference.
I'm only making the suggestion before someone throws down $300 for lights that don't appear to fit properly, and whose description seems ambiguous.
