09 corolla bulb/light sizes - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix Exterior Forum A forum for the discussion of 10th Gen Corolla and 2nd Gen Matrix exterior maintenance and modifications.
post #1 of 14 Old 08-13-2010, 02:35 PM Thread Starter
court155's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I haven't seen this info yet on here, and instead of digging google for it, here it is for everyone
2009 Toyota Corolla Car Light Bulb Size Chart
Low Beam Headlight Bulb Size: 9006
High Beam Headlight Bulb Size: 9005
Parking Light Bulb Size: 3457ALL
Front Turn Signal Light Bulb Size: 3457ALL
Rear Turn Signal Light Bulb Size: 3156
Tail Light Bulb Size: 7443
Stop Light Bulb Size: 7443
High Mount Stop Light Bulb Size: Assembly
Fog/Driving Light Bulb Size: H11
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 921
Front Side Marker Light Bulb Size: 168
Rear Side Marker Light Bulb Size: 7443
Map Light Bulb Size: 175
Dome Light Bulb Size: DE3175
Trunk/Cargo Area Light Bulb Size: 168
hope it helps
- The Court
72 Mustang Grande
87 Bronco II
89 Bronco II
05 Grand Am SE
09 Corolla S
court155 is offline
The Following User Says Thank You to court155 For This Useful Post:
knight runner (08-05-2014)
post #2 of 14 Old 08-13-2010, 02:56 PM
Senior TN Member
msncorolla422's Avatar
Quoted: 2 Post(s)
It has been posted before but thanks for the effect. Should have been easy to find in sylvania.com
msncorolla422 is offline
post #3 of 14 Old 08-14-2010, 08:46 AM
Vivir el momento
Quoted: 34 Post(s)
Good info.
Added to the sticky thread.
PhatRoyale is offline
post #4 of 14 Old 08-14-2010, 10:45 AM
The Corolla That Could
shotgunjimmy's Avatar
Quoted: 0 Post(s)
It should be noted that the cars without sunroofs use a diffent map light bulb. Those cars use a 168/194 bulb.
2009 Corolla S : Kenwood Kdc-x993, Polk MMC6500, Polk db651, Rockford Fosgate T110D2, Alpine Pdx.5
Magnaflow 2.25" Muffler, TWM Short Shifter and Base Bushings, Summit Engineering Shifter Cable Bushings, Tein S-Techs, V-Leds LED's, Enkei RPF-1 (18x8 +35), Inno IN-SU Roof Rack.
shotgunjimmy is offline
post #5 of 14 Old 09-30-2010, 08:28 PM
cu2cool's Avatar
Quoted: 0 Post(s)
Is there a separate DRL bulb from the lows and highs? If so, what is the size?
cu2cool is offline
post #6 of 14 Old 09-30-2010, 09:21 PM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 96 Post(s)
Canada
DRL is the high beam bulb, just at a lower wattage....
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline
The Following 2 Users Say Thank You to LeanBurn For This Useful Post:
cu2cool (09-30-2010), knight runner (08-05-2014)
post #7 of 14 Old 10-01-2010, 10:51 AM
10 Corolla S, 11 H/L SE
Quoted: 0 Post(s)
Alternatively, here is an interactive "bulb finder" for any make/model.
http://www.sylvania.com/ConsumerProd...lacementGuide/
thewalrus2010 is offline
The Following User Says Thank You to thewalrus2010 For This Useful Post:
cabur (10-01-2010)
post #8 of 14 Old 04-27-2011, 08:10 AM
Official Corolla Owner
corollachris's Avatar
Quoted: 0 Post(s)
whats up with the bulbs in the cluster????? what are they??
corollachris is offline
post #9 of 14 Old 04-27-2011, 08:18 AM
Lowdown Lowlife
FlawedLegacy's Avatar
Quoted: 1 Post(s)
iTrader Score: 14 reviews
what "cluster" are you referring to? the dash lights? those are all LED's soldered onto the boards.
2009 Magnetic Gray Metallic Corolla LE
^Click For My CarDomain Page^
Team HAMSTER
FlawedLegacy is offline
post #10 of 14 Old 01-13-2012, 10:57 PM
Quoted: 0 Post(s)
Would this fit my corolla s
10 Blue SMD LED T10 Festoon Dome / Map light
DarkCaLiBeR is offline
post #11 of 14 Old 01-14-2012, 12:31 AM
cu2cool's Avatar
Quoted: 0 Post(s)
If you're talking about something like this. Where you would have the adapter for the dome (DE3175), which is a 32mm festoon socket. The spring loaded one works fine, and is what I use for my LED panel. T10/194/168 bases should all work for the map lights.
LED Bulb Swap, Footwell LEDs, OBX Sport Pedals, 35% Tint, Bungie Trunk Mod, Red Out Tails, FIAMM Hi/Lo Horns, Smoked Eyelids, FX-R BiXenon Projector w/5k HIDs, LED Pipe Eyelids/CCFL Halos
To Do: LED Tails, Vinyl Roof, Oval Muffler Tip, DVD/Nav System, 18" Rims
cu2cool is offline
post #12 of 14 Old 01-18-2012, 07:54 PM
Quoted: 0 Post(s)
so if i put HIDs in, then i dont have to get rid of the DRL?
THATGUYTERRY is offline
post #13 of 14 Old 01-18-2012, 10:34 PM
cu2cool's Avatar
Quoted: 0 Post(s)
Low beam HIDs will not effect your DRLs. If you are talking about HIDs in the high beam, 1.) not recommended, 2.) DRLs would not function properly.
You should consider projector retrofits if you want HIDs. Makes a big difference (coming from someone who used to have PnP kit). It's already the latest buzz for other members.
http://www.toyotanation.com/forum/32...-retrofit.html
Angelo is selling them for $360 I think, but you still need to get your own ballast/bulbs/relay harness.
cu2cool is offline
post #14 of 14 Old 01-19-2012, 12:40 AM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1243 Post(s)
iTrader Score: 8 reviews
hope it helps
Originally Posted by PhatRoyale View Post
Good info.
This was listed & added to a sticky thread a long time ago. A simple search would have pulled it up. It can be found here.......
http://www.toyotanation.com/forum/14...need-know.html
89 Supercharged White MR2 MT/09 Corolla S TURBO CSM MT
95 Previa S/C White AT/06 Scion xB MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013) > Corolla 10th Gen/2nd Gen Matrix Exterior Forum
User Tag List
Linear Mode Linear Mode
Back
