don.t know about the drain plug but running a garden hose through the system is not a sufficent flush.
disconnect the coil from this distributor so it won't start. remove the drain plug let it drain. when done turn the motor over a few time until water stops comin out. fill it up and drain a couple times. put the plug back in fill with ratiator with radiator flush and run for a few minutes then repeat the fill and flush again. empty out the system then fill with distilled water(NOT TAP water) and coolant 50%/50%. there is other ways of doing this. ITs just how I do it.
4x4 v6 04 tacoma
Your Driving?Were we going?
