Replacement Aux Jack? - Toyota Nation Forum : Toyota Car and Truck Forums
10th Gen Corolla/2nd Gen Matrix Interior and Audio Forum A forum to discuss 10th Gen Corolla and 2nd Gen Matrix interior and audio maintenance and modifications.
post #1 of 56 Old 07-12-2010, 05:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I posted a while ago about some problems I've been having with the aux jack in my car. It seems like there's a loose connection, and if the cable is moved or bumped at all, even slightly, the radio switches from aux mode to the cd player as if the cable had been unplugged. It's now gotten to the point where it hardly functions at all.
I think I've narrowed the problem down to the jack itself and I think a replacement would quickly and easily solve this problem. However, when I called the dealership they said that a replacement part would cost $100. This seems like a $10-$15 piece of plastic to me at most, so hopefully someone here knows where I can get my hands on this part (I'm assuming the $100 quote from the dealer is for a full assembly of some kind, and not just the jack itself).
Here are two pictures of the part I'm talking about:
"Adapter Assy. Stereo Jack"
Model No. 86190-02010
Thanks!
BoingoBongo is offline
post #2 of 56 Old 07-12-2010, 05:39 PM
Ninja-rator
RningOnFumes's Avatar
Quoted: 4 Post(s)
I would say your best bet is to go to the Junk yards. I think you might be successful looking at any of the latemodel Toyotas that has an AUX. They wouldn't be stupid enough to make a different one of every car. Just be sure to take the one you have there with you for comparison.
RningOnFumes is offline
post #3 of 56 Old 07-12-2010, 05:49 PM
10 Corolla S, 11 H/L SE
Quoted: 0 Post(s)
Should be covered under warranty.
thewalrus2010 is offline
post #4 of 56 Old 07-12-2010, 06:07 PM
Boy Wonder
ChancreScolex's Avatar
Quoted: 0 Post(s)
iTrader Score: 6 reviews
Have you experienced the same thing when plugging other cables in?
2009 MGM Corolla S - My Garage
Debadged, Hood Dampers, Takeda SRI, 25/15 Tint, LED Dome/Map/License Plate Lights, Weathertech Rain Deflectors, Hella Supertones, Pioneer Premier AVIC-F90BT, 2 12" Pioneer Premier 1200w subs, Magnaflow Exhaust, TRD RSB/FSB/Springs, 18" Enkei EKM3's
ChancreScolex is offline
post #5 of 56 Old 07-12-2010, 06:24 PM
Senior TN Member
msncorolla422's Avatar
Quoted: 2 Post(s)
I've already seen some at local junk yards. but it should be under warranty
msncorolla422 is offline
post #6 of 56 Old 07-12-2010, 06:32 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I've tried different cables, so I'm sure it's the jack. I have to get my oil changed soon, so I'll see about a warranty repair and hopefully it'll get taken care of. Otherwise it's off to the junk yard!
post #7 of 56 Old 07-12-2010, 06:35 PM
Adama's Avatar
Quoted: 2 Post(s)
I have that Aux jack and the IPod jack out of a 08 Scion Tc that I was going to install in my Corolla but I bought a Pioneer stereo instead. The number on the back is the same as yours. If your interested, PM me an offer.
BC Racing Coilovers / 09 Xrs Rims / TRD F & R Sway Bar / TRD FSB / Alutec RSB / Tc Center Armrest / Tc HomeLink Mirror / Valentine 1 / ScanGauge II
Adama is offline
post #8 of 56 Old 07-13-2010, 10:03 PM
Quoted: 1 Post(s)
i am going through something similar..but its not the jack its the actual cable (mine would do the same as you described changed it no issues any longer)...from my experience aux cables no matter how much they cost..they only last 3-6 months..
2012 Camry Se| 20% LLUMAR Tint| 8000k HID kit lows/3000k fogs
roberto1187 is offline
post #9 of 56 Old 07-14-2010, 12:28 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I guess it might be possible that both of my cables are bad. Maybe I'll try and find another one and see if it fixes the problem.
post #10 of 56 Old 07-14-2010, 01:02 AM
Senior TN Member
Quoted: 2 Post(s)
mine cost $7 at Fry's and I bought it a week after I bought my car which is almost a year and a half ago(March 30, 2009) and it STILL works I use mine everyday and its one of those retractable ones I unplug it from time to time and i've had no issues, even when my friends accidentally yank it out from the back seat over and over again.
post #11 of 56 Old 06-24-2011, 07:35 PM
Deer Smasher
Elizle's Avatar
Quoted: 0 Post(s)
Sorry for reviving this dead post, but my brother just got his replaced at the dealership. Whoever replaced it left the old part on the floor of his car. I took it apart and the jack just has a bunch of bad solder joints. All you would need to do to repair it is either reheating the solder joints and repairing it that way. Or get some flux and some desoldering braid and remove what is probably crappy lead-free solder and replace it with some good old fashion lead solder. Pretty easy fix really. I told him I could have repaired it for free. I was right, oh well.
88 Corolla SR5 with Ksport Kontrol Pros ridin' on ADR Titan 18s
Ballin'
/////Alpine
Elizle is offline
post #12 of 56 Old 07-23-2011, 04:29 PM
Quoted: 1 Post(s)
Same issue, how was this resolved and how do you remove the defective AUX jack?
naicidrac is offline
post #13 of 56 Old 07-23-2011, 08:59 PM
E-Town GoldRolla
Andriy242's Avatar
Quoted: 0 Post(s)
Im not sure how they resolved it, but I am thinking cable repacement or jac replacement.
If someone needs a spare one i still have mine which I do not need.
And to take it apart. On the Back of the plastic casing pop of the top spacer (takes a bit of preassure)
and here is the jack inside the case
2009 DSM Corolla Click me?
Andriy242 is offline
post #14 of 56 Old 07-23-2011, 10:23 PM
2010 Corolla S
Quoted: 0 Post(s)
I have one laying around, although it is just the jack with no plastic housing. I'm re-using that for my car pc!
TFCommanderBob is offline
post #15 of 56 Old 07-24-2011, 10:42 AM
Quoted: 1 Post(s)
How do I get the plastic housing out? I need help with taking the existing AUX jack out of the vehicle. I didn't know if I have to remove that front piece of the dash or if the AUX jack with housing can just pop out of the front?
Thanks,
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 10th Gen Corolla/2nd Gen Matrix (2009-2013) > 10th Gen Corolla/2nd Gen Matrix Interior and Audio Forum
User Tag List
Linear Mode Linear Mode
Back
