"Satellite antenna with prewire"? - Page 3 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009- ) > 10th Gen Interior and Audio Forum
10th Gen Interior and Audio Forum A forum to discuss interior and audio maintenance and modification.
Old 12-10-2009, 05:03 PM   #31 (permalink)
View erock9174's Photo Gallery
cool thanks for the info. I plan on hooking up my Stratus 6 to the shark fin to take advantage of the factory antenna. I was scared that by plugging in the sirius that it might disable the am/fm antenna cause I thought it ran through the shark fin as well.
erock9174 is offline   Reply With Quote
Old 01-04-2010, 10:42 PM   #32 (permalink)
Anyone have pics or instructions on how to remove all the front kickpanels and side sill trim panels that go down the side of the car ?
I plan on running my Sirius antenna from the front glove box to the trunk and need help in routing it.
Originally Posted by tommy7777 View Post
There is a jack located in the trunk underneath the cardboard/felt covering on the right side. Just pull that down and you will see the jack. That jack is only for the shark fin cable that will go to the XM/Sirius radio. It will not work for AM/FM.
If you have a portable, you can use the cigarette lighter to power, run the antenna from the trunk to the front of the car. You will need to plug the XM receiver, the shark fin antenna wire from the trunk, the cigarette lighter adapter and a wire from the radio AUX into the XM tuner.
Old 01-05-2010, 11:05 AM   #33 (permalink)
View sienna1's Photo Gallery
Canada
http://www.trdsparks.com/install/PT922-02080-01inst.pdf, http://www.trdsparks.com/install/PT546-02080inst.pdf and http://www.trdsparks.com/install/PT545-00082Corolla.pdf should give some clues.
sienna1 is offline   Reply With Quote
Old 01-05-2010, 11:16 AM   #34 (permalink)
thanks a bunch.
