LED electronic flasher - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009- ) > 10th Gen Interior and Audio Forum
10th Gen Interior and Audio Forum A forum to discuss interior and audio maintenance and modification.
Old 06-30-2009, 03:00 PM   #1 (permalink)
btk
btk's Avatar
View btk's Photo Gallery
hey guys, im thinking about doing an led turn signal swap, and for that, im going to need the led electronic flasher from vleds to eliminate the hyper flash/bulb burnout indication.
i was wondering if any of you know how to remove the stock flasher unit? i've tried getting to behind the cluster/steering wheel panels, but i couldn't...
any input is greatly appreciated. thanks!
btk is offline   Reply With Quote
Old 06-30-2009, 03:48 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $436410
iTrader Score: 12 reviews
View bandit's Photo Gallery
I dont know how it is on the Corolla but take a look at the one for my 2009 Camry
Master List of LEDs Bulb Sizes & DIY/Tutorials for Interior/Exterior Lights
CarDomain
Old 06-30-2009, 05:00 PM   #3 (permalink)
btk
btk's Avatar
thanks, i had a look, but the corolla has no screws on the dash :S and im so lost as to how to remove the instrument panel.. i cant even get the cover off lol.. i tried pulling on the side silver trims.. managed to get the bottom one off but i couldn't remove the top portion..
someones got to have removed the instrument panel yes? i know a few of you have replaced your instrument panel leds.. if you have, please do share as to how you removed the panel.. i just hope the flasher is behind that :S
thanks guys
*ADDITION*
and hey dc, i looked through a couple of your pictures on photobucket and i noticed that you got yourself a different remote with the folding key for your car... whered you get it? and is it available for any toyota models?
Thanks!
Old 06-30-2009, 05:27 PM   #4 (permalink)
johncal's Avatar
View johncal's Photo Gallery
Good LED units have a load resister built in so you don't have to change your flasher.
JDM yellow fog bulbs, Cool Blue Headlight bulbs, Modified Intake, TRD air filter, billet shifter knob, modified light sensor, Carbon Fiber Dash, 30% Window tint, tinted reverse lights, signals, de-badged, MSW type 12 wheels, Eagle GT 225/40-18 tires, additional brake lights, TRD sway bar, Lowered
johncal is offline   Reply With Quote
Old 06-30-2009, 10:11 PM   #5 (permalink)
Pie
View Pie's Photo Gallery
thanks guys
Thanks!
I think you just pull it. I was looking at the Blu Logic installation instructions:
http://trdsparks.com/install/PT923-00090instCorolla.pdf
On Page 11 it says to pull it and you should have access to the gauge cluster.
Pie is offline   Reply With Quote
Old 07-01-2009, 12:33 PM   #6 (permalink)
must.resist.modding
bandit's Avatar
Thanks!
I got the key on eBay
Key must be programmed and cut by dealer or locksmith. I had to take it apart to give the locksmith the key only as the whole thing wont fit in their vice to cut.
If its used for turn signals, you will need a flasher module or load resistors installed. The wattage produced by the LED is far less than stock. Since its less wattage, the computer in the car will think the bulb is out or hyper blink.
Vleds, superbrightleds, autoluminations all sell quality bulbs with resistors in them, they still hyper blink.
CarDomain
Old 07-01-2009, 02:31 PM   #7 (permalink)
btk
btk's Avatar
I want one for my car! Do you still have the ebay link? I cant seem to find it...
Thanks!
Old 07-01-2009, 04:37 PM   #8 (permalink)
must.resist.modding
bandit's Avatar
Thanks!
Search for "corolla flip key"
http://shop.ebay.com/items/?_nkw=cor...+key&_osacat=0
Direct link. I dont know which key you have but
4 button key
http://cgi.ebay.com/ebaymotors/06-07...lenotsupported
3 button key
http://cgi.ebay.com/ebaymotors/2005-...lenotsupported
CarDomain
Old 07-02-2009, 08:25 PM   #9 (permalink)
johncal's Avatar
There is a difference between a load resistor to prevent hyperblinking and the normal load resistor that an LED needs to prevent itself from burning out instantly (or nearly instantly). The resistors I am speaking of fool the flasher into thinking there is a large incandescent type of load on them.
My apologies if I was confusing.
Here is some good info that might help......
Why does turn signals flash faster after retrofitting with LEDs?
This is actually a normal response from turn signal curcuit. The curcuit is load sensitive and this is the way to tell the driver that one or more bulb is out. LEDs draw less current than filament bulbs, and it "sounds" like a bulb is out. There are 2 solutions to this:
Add in a couple of 10W resistors in paralell to increase load, but that is going backwords in technology. One of the advantages of using LEDs is less power consumption.
Modify flasher unit. This is only possible on 3 terminal types.
Replace flasher under the dash to a load insensitive type. They are sold in automotive stores. They are typically named "heavy duty" units because they can handle load of many extra turn signal bulbs. Truckers typically use them. You have probably seen them having 6-15 turn signals. An example of a such a truck flasher is the top one here. Normally they would have a different physical size and pinout compared to OEM unit. Procedure would be something like this:
1) get an aditional OEM flasher unit - if only 2 terminal, ground needs to be added as well
2) get a generic load insensitive flasher unit - 3 terminal
3) remove incapsulation on both units
4) glue/solder (2) into (1).
5) now it will plug directly into factory harness socket.
You can also make a flasher yourself with a an integrated curcuit like 555 or CMOS 4060. The 4060 only requires a single resistor and a capacitor to flash connected to pin 9, 10, and 11. See http://www.starshipmodeler.com/tech/cj_blink.htm for details. The outputs of 4060 can be loaded with 10mA which is enough to drive a small transistor/relay or a FET transistor. All parts should be less than $5, even cheaper if u can find some old computer/stereo system to strip parts from. Contact Herman (heranker@yahoo.ca) - he can rebuild any 3 terminal flasher unit to load independant for US$65.
Old 07-03-2009, 01:16 PM   #10 (permalink)
must.resist.modding
bandit's Avatar
The two things that prevent hyper flashing and bulb out warning are load resistors (splices factory wire) and electronic flasher module.
Very good info but the 10w is wayyyy too less. All the LED sites I got to offer 6OHM or 3OHM. Both being 50w.
If you know wiring and all this stuff, you can modify your stock flasher but if you mess up, you'll be paying $30-50 to the dealer for a replacement. An aftemarket/3rd party flasher module handles both LED and filament bulb for only $17 or so.
CarDomain
Old 07-03-2009, 04:26 PM   #11 (permalink)
btk
btk's Avatar
i have yet to locate the flasher module =(.. i'm going to try and take it apart again today.. im having a hard time taking apart the trim around the radio (silver/grey)
Old 07-03-2009, 07:09 PM   #12 (permalink)
must.resist.modding
bandit's Avatar
I dont know if there is a site dedicated to Corolla's but see if there is a site that has service manuals or google search. I know for the Camry, we have www.camrystuff.com
CarDomain
Old 11-09-2009, 10:31 PM   #13 (permalink)
View andrewwoo's Photo Gallery
oh wow the Switchback Turn Signals is amazing!!! you think in the back too is ok?
2009 BLUE Streak Metallic Toyota Corolla S
6000K HID Retrofit TL Projectors| 6000K HID H11 LEDs | Interior White LED Lights | White Cathode Trunk Light
Door Sills | Factory Remote Starter | Ipod Adapter | 15% High Performance Metallic Tint
TRD RSB | UR 19mm RSB | UR LB
andrewwoo is offline   Reply With Quote
