After you remove the trim there are 4 screws that need to be removed. I did it with a tourque wrench set (15 bux from Home depot) with those four screws removed give the head unit a bit of a tug. the ac vents on top of it will come out also but its fine. the ac units clip in and out. the head unit will come out with the bracket. unscrew the old. screw in the new. slide back in. slide in the ac vents. screw the 4 mounting screws (the ones you tourqed out) and then slap in your trim. enjoy..
2009 Corolla LE
De-Badged, Sirius (Hardwired), Modified Air box, Rain Gaurds
