2009 Corolla Air Filter Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix Interior and Audio Forum A forum to discuss 10th Gen Corolla and 2nd Gen Matrix interior and audio maintenance and modifications.
post #1 of 24 Old 03-11-2010, 10:54 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Where does one find the air filter in an '09 corolla? I bought a replacement filter from Autozone per their parts book and it does not fit the filter behind the glove box, so I'm thinking it's for the external intake. Does anyone know where to find this? I can't find useful information in the user's manual...
Weaseal is offline
post #2 of 24 Old 03-11-2010, 11:09 AM
2010 Corolla S
Quoted: 0 Post(s)
http://www.trdsparks.com/displaypart...&parts_id=2714
A quick search across the forum will yield multiple thread hits... If you type "cabin air filter" into the search you'll be able to locate a thread with Jeff Lange(sp?) stating the precise model numbers as well.
There. I've given you both a fish and a fishing pole. Perhaps some bait as well
TFCommanderBob is offline
post #3 of 24 Old 03-11-2010, 11:37 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the quick response but I wasn't asking for a parts list. I'm asking for a location in the vehicle. Thanks.
Weaseal is offline
post #4 of 24 Old 03-11-2010, 11:59 AM
uh..no, it's not a hybrid
LeanBurn's Avatar
Quoted: 93 Post(s)
Canada
There are 2 filters. One in the engine bay, the engine air filter...biggest black box right next next to the valve cover. There is also one behind the glove box, the Cabin air filter. 2 very different filters. Not sure if you need further info, or if this is what you were after....
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.111L/100km(38.761mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline
post #5 of 24 Old 03-11-2010, 01:15 PM
2010 Corolla S
Quoted: 0 Post(s)
Hah, indeed I'm still confused as to what you are asking. The location of the engine's air filter? Its under the the big black box with hoses coming off it in the engine compartment. Pop the clips and you can lift up the lid.
post #6 of 24 Old 03-11-2010, 07:27 PM
It needsa muffler bearing
Quoted: 0 Post(s)
2010 Corolla S Black-Auto-Fujita SRI-Debadged -Mobil 0W-20 Oil-Nokya Yellow Fogs-All led swap-TRD FSB-TRD Lowering Springs-DDM 6k HID-Shift boot/CF Shift Knob-20/35 Tints-Tenzo r Cuzco Wheels-SmokeTail Lights
On the way: Borla exhaust-DC Sports Headers
ej063090 is offline
post #7 of 24 Old 03-12-2010, 12:37 AM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1134 Post(s)
iTrader Score: 8 reviews
I second that!
I very confused on what the op is asking for. The engine air filter is obvious or so I thought. The cabin air filter is behind the glove box. I believe the manual will show the location for each filter.
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #8 of 24 Old 03-12-2010, 01:36 AM
Senior TN Member
thestone11's Avatar
Quoted: 0 Post(s)
simplest solution: take your car back to the dealership and pay them to replace it for you. Or get the parts from the dealer and do it yourself.
Both of the filters could be found in basically any big auto store too.
The one in the engine bay is the air filter for the engine. The one behind the glove box is the cabin filter.
1985 Corolla GTS (AE86)
2002 Mazda Protege 5 (Sold)
2009 Corolla S: http://www.cardomain.com/ride/3820536
thestone11 is offline
post #9 of 24 Old 03-12-2010, 10:48 AM
Quoted: 0 Post(s)
Oddly enough, it only shows the location of the cabin air filter. I searched the owners manual and couldn't find a single diagram stating the spot for the air filter. Its a conspiracy.
pwain is offline
post #10 of 24 Old 03-12-2010, 10:51 AM
FlameyFart's Avatar
Quoted: 0 Post(s)
Why are people getting on his butt?
He said he bought an air filter -> it does not fit in the slot behind glove compartment -> he thinks its for the intake -> where is the location?
Is that not clear enough?
2010 Corolla LE (MGM)
FlameyFart is offline
post #11 of 24 Old 03-12-2010, 12:09 PM
2010 Corolla S
Quoted: 0 Post(s)
Disclaimer: None of this post is meant to belittle anyone or be a personal attack upon anyone. I'm explaining my logic for giggles, even if it only amuses me.
I don't think we are being rude, "getting on his butt". We are simply stating it was an unclear line of thought. I think your perception of clarity comes from having the whole thread to interpret from, rather than just the first post. Here are my lengthy perceptions:
OP read to me as:
I bought an air filter-> it didn't fit where I tried it-> where can I buy the one that goes where I tried to fit it.
I made the (incorrect) assumption that he was trying to replace the cabin filter and that "where to find this" was a plea for a vendor of the cabin filter. My assumption came from the thought that if I buy something that isn't what I thought it would be, I return it and try to get what I needed. If he is trying to stick it in the cabin filter slot, he must need a cabin filter.
The only qualifier for location (vendor vs car) is the word "in" in "find the air filter in an '09 corolla" which (to me) still isn't clear. I feel in that situation "in" is used interchangeably with "for." Given the order of the information, you don't yet know which filter he is talking about, or even that there could be two. His second question uses "this" thereby forcing you to infer the intended filter from the previous sentence. So if you had guessed "vendor" when you read the first sentence, you'd infer "cabin" when you read the third, or "car" -> "intake".
A clear question, using only the information given in the first post, might read:
"How do I install the external intake filter?"
Because:
He decided that the filter he bought was for the "external intake," and that he'd like to use it anyway, but didn't know how to install it.
But I digress...
If you decide I put too much thought into this post, read this article. It is more geared toward a project style forum, but it has some application to a lot of the threads posted around here
http://catb.org/~esr/faqs/smart-questions.html
post #12 of 24 Old 03-12-2010, 12:31 PM
FlameyFart's Avatar
Quoted: 0 Post(s)
Haahaha. Touché!
post #13 of 24 Old 03-13-2010, 12:20 AM
Diehard Rams Fan
As I already stated, I thought the engine air filter was obvious where it goes. I would guess that anyone that would buy an air filter to replace themselves would know where the air filter was housed. When looking under the hood, there is really only one place where it could be ........ and that's where it is!
post #14 of 24 Old 03-26-2010, 03:41 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Lol, this post generated way too much discussion. Flamey got it right, sorry if I was unclear. Yes, I bought the wrong filter (meant to get cabin air, instead got engine intake) but my question was, since I've got this engine intake filter, where do it go? And as someone else stated, it is completely lacking from the manual. Toyota manuals tend to be pretty terrible compared to other brands.
Weaseal is offline
post #15 of 24 Old 03-29-2010, 04:43 AM
bazzle91's Avatar
Quoted: 0 Post(s)
It's really easy, just look at the box and there's metal clips holding the top and bottom portions together at a halfway mark between the two pieces. unclip, take out the filter (pay attention to what position it was in before you take it out), and put the new one in according to how the old one was sitting. My best advice = dont' change your filter until you really need to. Why waste the one you already have in there? Make use of it. Unless you bought a TRD high flow or some form of an intake I wouldn't bother to change a slightly used paper intake filter to a newer one of the same class.
2009 Corolla S BSP A/T 4-Spd
-TRD filter w/ Intake Mod/2" Magnaflow Exhaust
-2500k Nokya Yellow Fogs w/ 35w 5000k HID low beams
bazzle91 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013) > Corolla 10th Gen/2nd Gen Matrix Interior and Audio Forum
User Tag List
Linear Mode Linear Mode
« Back
