Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Cutting Springs?
View Single Post
Old 04-13-2002, 10:16 PM   #5 (permalink)
goodcookiedrift
Banned
View goodcookiedrift's Photo Gallery
On 2002-04-13 22:49, Shaun wrote:
On 2002-04-13 21:13, fatredcircle wrote:
Theres nothing wrong with cutting your springs, as long as youdon't trim too much off of it. it ain't rice rice, just don't chop them to like 2 coils left u know?
chopping springs will screw up spring rate and give a screwed up ride and mess up handling...also theres no compensation for the shorter ride height...making ur car more prone to bottoming out
thats why you get short strokes...a spring is a spring is a spring...chopping will only make it stiffer if anything. Its not that bad...the only concern is the spring slipping out of the perches...if you can find a way to level out the cut spring to sit on the perch flush, you should be okay.
Nick
goodcookiedrift is offline   Reply With Quote
