Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Dash Lights Out
Thread: Dash Lights Out
View Single Post
Old 08-29-2010, 09:17 AM   #11 (permalink)
musclecar64
View musclecar64's Photo Gallery
I think this is probably the most common issue I've seen with our corollas. Check the wiring for your stereo harness. There are two orange wires, one is dimmer, one is dimmer ground. These should NOT be connected. Cut them and tape the ends off. If you did wire these together, you probably fried the dimmer rheostat, in which case your lights won't come on unless you replace this. Check the resistance on the rheostat. You also may or may not need to replace your radio/cig outlet or other fuses. Get the rheostat at a junkyard for like $15 and save yourself about $150 over toyota
Edit: oops, didn't realize this was a really old thread.
musclecar64 is offline   Reply With Quote
