Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 22re Turbo Questions
View Single Post
Old 04-25-2004, 03:30 AM   #3 (permalink)
jdougall
View jdougall's Photo Gallery
You can check out www.lcengineering.com for pistons, cam, etc... I would recommend dropping compression down to 8-8.5:1 with forged aluminum pistons if you want to run high boost. This would also require valves, cam, and depending on how crazy you want to get, it would require injectors. If you want, you could leave the motor stock, slap a turbo on and run with about 5lbs of boost, and be fine with running 91.
jdougall is offline
