Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - does anyone know how to override the speed and fuel governor in the 2000 GTS, AT
View Single Post
Old 09-15-2010, 12:58 PM   #7 (permalink)
jmk1977
View jmk1977's Photo Gallery
Normally a chip will remove the limiter. If you could pull up a wire diagram you could find the kill switch yourself.
If its just a fuel signal that gets lost (the cpu cuts pump power) run your own power line with a tie in to a positive ignition wire that way when you hit the ignition the pump starts as normal.
Or run a switch (toggle or rocker)
jmk1977 is offline   Reply With Quote
