Below is a list of all the settings that can be customized on the 2017 Highlander using Carista 3.4.1 (http://www.caristaapp.com/). The main thing I was hoping Carista could do was stop the annoying 5 beeps when I start the car and beeping when I have the door open; which I don't think can be turned off using Carista or Techstream.
Items with *ASTERISKS* around it are my chosen settings:
Doors / Windows / Remote
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unlocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / *MAX*
Beep when opening/closing windows with remote
*YES* / NO
Warn (beep) when door can't be locked because it's still open
*YES* / NO
Warn (beep) when sunroof is still open when locking doors
*YES* / NO
Panic function on remote
*ENABLED* / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / *120 SECONDS*
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock all doors
DISABLED / WHEN SHIFTING INTO GEAR / *WHEN VEHICLE STARTS MOVING*
Auto-unlock all doors
DISABLED / *WHEN SHIFTING INTO PARK (P)* / WHEN DRIVER'S DOOR IS OPENED
After locking with smart key, don't allow re-opening within…
*0.5 SECONDS* / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Open trunk via smart access button
DISABLED / DOUBLE CLICK / *LONG PRESS*
Open glass hatch via smart key
*YES* / NO
Open windows and sunroof by holding key in door lock
ON / *OFF*
Close windows and sunroof by holding key in door lock
ON / *OFF*
Open windows and sunroof via long-press on remote
ON / *OFF*
Open/close power rear hatch via interior switch (click type)
SINGLE CLICK / *LONG PRESS*
Beep while opening/closing power rear hatch
YES / *NO*
Unlock via "One motion"
REAR HATCH ONLY / *ALL DOORS*
Open rear hatch via "One motion" remote
DISABLED / SINGLE CLICK / DOUBLE CLICK / LONG PRESS / DOUBLE CLICK ON UNLOCK BUTTON / *LONG PRESS ON UNLOCK BUTTON*
Rear hatch open assistance
Rear hatch close assistance
Rear hatch max open level
1 / 2 / 3 / *4* / 5
Instruments / Display / Dings
Engine start indicator
*ON* / OFF
Display odometer after ignition is turned off for…
30 SECONDS / *1 MINUTE* / 10 MINUTES / OFF
Ding when headlights are left on
*YES* / NO
Seat belt warning ding (driver)
Seat belt warning ding (front passenger)
Seat belt warning ding (rear passengers)
Turn signal click volume
LOW / MEDIUM / *HIGH*
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / *4 FLASHES* / 5 FLASHES / 6 FLASHES / 7 FLASHES
Remote low battery warning
*ON* / OFF
Rear parking sensor range
NARROW / *WIDE*
Mute parking sensor when stationary for more than 3 sec.
YES / *NO*
Parking sensor beep volume
1 / 2 / 3 / 4 / *MAX*
Activate parking sensors in neutral (N)
*YES* / NO
Enable front parking sensors when in reverse (R)
*FRONT* / OFF
Enable rear parking sensors when in neutral or forward gear
*REAR* / REAR CORNER / OFF
Dash display mode
*ALL* / UNDISP
ECO Drive indicator zone
*ON* / OFF
Lights
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / *LIGHTEST*
Instrument lights dimming sensitivity
DARKEST / DARKER / *NORMAL* / LIGHTER / LIGHTEST
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / *30 SECONDS*
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Turn on exterior footlight (on side mirror) when smart key in range
*YES* / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
*YES* / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
*YES* / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / *30 SECONDS*
Interior lights linked to footlight
*YES* / NO
Interior light control
Exterior light control
Heater & A/C
Temperature dial calibration
-2°C / -1°C / *NORMAL* / +1°C / +2°C
Ambient temperature calibration
-3°C / -2°C / -1°C / *NORMAL* / +1°C / +2°C / +3°C
A/C power
*AUTOMATIC* / FULL POWER
Auto-increase blower speed when front defroster is on
*YES* / NO
Auto-turn on A/C when AUTO button pressed (if needed)
*YES* / NO
Deactivate front defroster when AUTO button pressed
*YES* / NO
Also blow to feet in "face" mode
*YES* / NO
Open vents to outside air when ignition is turned off
*YES* / NO
Fan speed reaches its target…
SLOWLY / *NORMALLY* / FAST
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Auto-lock all doors
*YES* / NO
ON / *OFF*
ON / *OFF*
ON / *OFF*
YES / *NO*
1 / 2 / 3 / *4* / 5
*ON* / OFF
*YES* / NO
*ON* / OFF
NARROW / *WIDE*
YES / *NO*
*YES* / NO
*FRONT* / OFF
Dash display mode
*ALL* / UNDISP
*ON* / OFF
Lights
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Heater & A/C
A/C power
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
