My new Head Unit - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander 3rd Generation (2014+) Forum dedicated to the discussion of 3rd generation Toyota Highlanders.
 9Likes
post #1 of 31 Old 04-20-2017, 09:36 AM Thread Starter
Quoted: 6 Post(s)
(Thread Starter)
My new Head Unit
I replaced the crappy head unit in my 2016 LE with a Dasaita Android unit. I am pretty impressed so far. The steering wheel controls work. It has two extra USB ports and built-in GPS. It has i-Go navigation installed. I use my phone as a hotspot and use google maps. It has Bluetooth so you can connect to the Bluetooth OBD2 readers. It, of course, reads your texts and hands-free phone. The best part is that it is fitted for our dash so it doesn't look like an aftermarket system. It's a 10.2" display and has an 8 core processor.
Here is the link to the eBay store where I got the head unit. Its all plug and play. No wires had to be cut and everything that worked before still works.
Click image for larger version
ID:	116890   Click image for larger version
ID:	116898   Click image for larger version
ID:	116906   Click image for larger version
gunnermike53 is offline
The Following User Says Thank You to gunnermike53 For This Useful Post:
rockett1021 (04-20-2017)
post #2 of 31 Old 04-20-2017, 09:47 AM
kayin's Avatar
Quoted: 36 Post(s)
Cool! How was the install? Pretty straight forward, or did you need extra connectors, etc? I'm assuming backup cam still works?
'09 Corolla S
'17 Highlander SE
kayin is offline
post #3 of 31 Old 04-20-2017, 09:48 AM
Quoted: 9 Post(s)
Is it me or does it rest just in front of the dash?
Any install pics?
Scorponox is offline
post #4 of 31 Old 04-20-2017, 09:55 AM
Quoted: 8 Post(s)
That's pretty dang clean for aftermarket
Sent from my XT1254 using Tapatalk
jtnova is offline
post #5 of 31 Old 04-20-2017, 10:06 AM Thread Starter
Quoted: 6 Post(s)
(Thread Starter)
Dash disassembly was super easy. It came with a wiring harness. It was plug and play. No cutting wires. The backup cam works the same other than the picture is 6 inches bigger!
kayin (04-20-2017)
post #6 of 31 Old 04-20-2017, 10:09 AM Thread Starter
Quoted: 6 Post(s)
(Thread Starter)
Any install pics?
No, it goes back in the same way the OEM did. The screen is tilted toward the driver slightly. I have some USB buttons coming in on Friday and will have to take apart the dash again so I will take some pics of that.
post #7 of 31 Old 04-20-2017, 10:38 AM
Quoted: 0 Post(s)
Which model did you get?
2017 Highlander Hybrid Limited Platinum.
AZFrosty is offline
post #8 of 31 Old 04-20-2017, 10:42 AM
Quoted: 49 Post(s)
Wow! Looks good! More pics of it in action please. How's the performance? What is the model number and where did you buy it from?
dingmah is online now
The Following User Says Thank You to dingmah For This Useful Post:
gunnermike53 (04-20-2017)
post #9 of 31 Old 04-20-2017, 10:49 AM Thread Starter
Quoted: 6 Post(s)
(Thread Starter)
This is where I got it from. It boots up in about 3 seconds. It performs like an 8 core android tablet, which is to say great.
AZFrosty (04-20-2017)
post #10 of 31 Old 04-20-2017, 11:23 AM Thread Starter
Quoted: 6 Post(s)
(Thread Starter)
I added a picture of the wiring and a link to the head unit to the OP.
post #11 of 31 Old 04-20-2017, 04:09 PM
Toyota Fanatic
Camry_wiz's Avatar
Quoted: 189 Post(s)
Do you know if this works with the premium JBL sound?
2007 Camry SE 2.4 - Modded
2004 Corolla S 1.8 - Stock
2004 Lexus RX330 3.3L - Stock
Check out my DIY backup camera install on my Gen6 Camry!
Camry_wiz is online now
post #12 of 31 Old 04-20-2017, 05:29 PM
Quoted: 47 Post(s)
Can you still change the settings of your car or no? (Interior/Exterior Light Settings etc.)
2017 Highlander XLE / Colors: Celestial Silver Metallic / Black
Mods: Front: Bull Bar / Side: Aluminum Running Boards / Rear: Double Layer Bars
TurboGPX is online now
post #13 of 31 Old 04-20-2017, 05:40 PM
Quoted: 47 Post(s)
The description says it has Apple mirror function. Don you happen to have an iPhone/iPad to test it out ? Thanks!
post #14 of 31 Old 04-20-2017, 05:52 PM
Quoted: 85 Post(s)
Wow according to the link it was only $448! The rep at the dealer told me it was $4000 to replace so I bought the extended warranty.
MARQEVANS is offline
post #15 of 31 Old 04-20-2017, 06:36 PM
2014 Highlander V6 2WD LE
Phil Indeblanc's Avatar
Quoted: 928 Post(s)
Nice!
Do you know how many volts output the audio is?
Can it do Android and or Carplay?
Can you connect it via USB and use the screen to interface to the phone particularly for Google Maps?
As far as it looking like it sits forward..The HL dash is not flat at in that area of the dash. the top lip comes out and then sets back in, so if the unit is going to be flush at any point, it will look like its a bit out on the right compared to the left of it. Your eye either needs to adjust to it, or you will just think its not like original and worry about it :-)
_____________
2014 Highlander, 2WD, V6, LE, HID/LED, AudioUpgrade
Phil Indeblanc is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Highlander Forum > Highlander 3rd Generation (2014+)
User Tag List
Linear Mode Linear Mode
Back
