2017 highlander has anyone been able to install led lowbeams on the 2017 highlander?
Steve will these fit a 2016?Hi Guys,
Thank you for your interest in the new Xtreme LED pro bulbs![]()
As per your questions:
(1) Our new H11 Xtreme LED pro bulb is still about 50% brighter then a standard H11 halogen bulb. While it's not as bright as HID, it is still significantly brighter than halogen (bright enough for some people), and you also get all of the benefits that @Phil Indeblanc listed above.
(2) You would not need to drill your dust cover when installing this kit in the low beams if you chose not to.
(3) Keep in mind that an H16 LED kit variant is available which is roughly 2-3 times brighter then your stock H16 halogen fog light bulb.
Steve
Call and ask a Yota engineer why the design change. What's the difference, right? For one, I've got an LED DRL strip. Is this the reason why they were added? Dunno. BTW, we call them "dust covers", but that is not what Yota calls them.I would just do as the '14, '15, '16 's are....with no dust covers.
My money is on keeping moisture away from the LED DRL strips, but what do I know?!?!?Yes, I would think its to keep dust out of the inside.
