Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 00 Avalon -need help
View Single Post
Old 04-28-2004, 08:27 PM   #6 (permalink)
ekpolk
The Regenerator
ekpolk's Avatar
View ekpolk's Photo Gallery
Originally posted by csaxon
kbass888 Remove the 5 screws 3 top 2 bottom (1 each side). Use screwdriver (tape it) remove lower panel and disconnect the airbag connector. Remove filter cover. Pull out filter and remove element from the frame. Put in new filter element re-install filter. Install filter cover. Re-connect airbag connection. Reinstall glove box.
csaxon: Your instructions are incorrect. Toyota's TSB on this subject specifically says NOT to disconnect the airgbag harness. It also has specific instructions where to "displace" the harness while performing this operation, so as not to damage it. You've also omitted the warning about not pinching and damaging the airbag wiring, although that certainly seems pretty self-evident. There's also a step for dealing with the trunk opener switch that's also in the way, so as not to damage it, the a/b harness, or the filter. See Toyota TSB AC006-99.
ekpolk is offline   Reply With Quote
