Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2000 Sienna Instrument Cluster Lights
View Single Post
Old 01-24-2011, 09:33 PM   #5 (permalink)
ceetom1
View ceetom1's Photo Gallery
instrument light replacement on 99 sienna
Originally Posted by arturo View Post
Once you pull out the cover for the radio look under it, the screws are facing up. You don't need to remove the radio. Shine a light upwards and you should see two screw. Hope it helps.
Yes, I found the two screws behind the radio and that did the trick. Those two screws lock in place the two legs of the large panel. I was able to remove the large front panel and replaced the burnt out lights. Thanks for your help.
ceetom1 is offline   Reply With Quote
