Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2003 V6 Camry failed smog check with P0500
View Single Post
Old 03-04-2011, 07:28 PM   #6 (permalink)
apexbrit
View apexbrit's Photo Gallery
Clean at Tailpipe-failed with po500 code
2003 Camry never showed a check engine light until I tried to smog per California law. On the dyno machine it immediatly threw a po500 code that would clear after a few starts. I called Calif consumer Affairs and was told this is a common problem. They gave me the number to scedule a test with the Referee at the local Jr. college. Will let you know how it turns out. Apparently when the car is put on the dyno, front wheels turning, rear stopped, the computer detects a skid and the ABS system causes the code to throw.
Took the Camry to the referee at Santa Rosa Junior College. I was in and out in 10 minutes; passes smog and charged $8.75 for the certificate.
apexbrit is offline   Reply With Quote
The Following User Says Thank You to apexbrit For This Useful Post:
amudhan (04-01-2011)
