Originally Posted by ibraimo
sorry again!
but the car is 1999 year model!
and i always made that test and it works!
now i donīt know the meaning off that error 53(seen on the engine light flashes)!
and the airbag system have this errors:
what this means?
hugs!
For the check engine lamp - you have to use a scanner. For the airbag light, you can use the short pin method.
Given you model year - it will have a DLC (Data Link Connector) and follow ISO protocols for communications, to allow you to access the stored code for the MIL (Malfunction Indicator Lamp).
For the SRS (Supplemental Restraint System), you can use the short pin method to query its trouble codes.
That is why I'm confused, your earlier post mentioned "engine" light, where as this new post is on the SRS system. Which lamp is on - the check engine or airbag??
