For the rear window:
Gently push in tabs in the two ends and then pull the lamp out completely...when out you will be able to see the bulb.
For the rear bulbs:
remove everything from the trunk...then open those screws, remove the plastic panel....One thing i didn't have in my tool box..what was needed was longer rachet attachments. The regular ones' didn't work. a mere 7 dollar investment for a set. The long screws that stick out are the ones you need to unscrew..and then work from there...its fairly SIMPLE! pm me if your still confused.
 Desi Toyota Dude Here!!!
