Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 9th Gen Toyota Corolla Maintenance Guide
View Single Post
Old 11-03-2011, 11:17 AM   #8 (permalink)
fishexpo101
Gearhead
Gameroom cash: $196215
Originally Posted by ajoneja View Post
In my 2006 Corolla 1.8L 1ZZ-FE (Canadian Model) Owner's Manual, I have the following:
Oil capacity (drain and refill),
L (qt., Imp. qt.):
1ZZ-FE engine
With filter 4.2 (4.4, 3.7)
Without filter 4.0 (4.2, 3.5)
2ZZ-GE engine
With filter 4.4 (4.7, 3.9)
Without filter 4.2 (4.4, 3.7)
Can you please confirm? I have my first oil change coming up since I bought it on Aug. of this year, so I just want to be sure.
Thanks.
In the 2006 models, made after February 2006 - they increased the oil capacity on the engines, as well as recommend the switch to 5W-20 motor oil. No worries, same engine, same sump capacity - different dipstick markings. Stick with the fluid capacities and oil weights as recommended by your owner's manual - unless you plan on running an extended oil change, etc. In that case - you are monitoring (or should be monitoring) oil quality carefully, so you can deviate from the manufacturer's recommendation.
