I have the 2009 toyota corolla which I have been doing oil filter change every 7500 miles and a tire rotation.
I now have 30k miles on the car.
As many on this forum have suggested that the 30k,60k,90k mile service is a rip-off, please let me know what specific services I should get between now and 100k miles.
An easy way to do that is to use Toyota's Maintenance Guide to find out what are the recommended procedures, replacements, inspections, etc., for the different service intervals. Just enter your Corolla's information.
Since I dont know how to check the liquid levels of misc ones, what I am asking is what should be the kinds of a la carte services I should be looking at and at what mileage ?
Examples
power steering flush
transmission flush
engine flush
brake fluid flush
and so on..and at what mileage should this be done.
Examples
transmission flush
engine flush
brake fluid flush
Power steering is electric, no fluid.
Transmission fluid, drain & refill just like the engine oil.
Engine flush, not needed, just change the oil & filter.
Brake fluid flush. I was told to not flush the brakes, just bleed them very easy.
Manual will list milage to do each item in the maintenance area.
The transmission fluid supposedly doesn't have to be changed until 100k, but I find that BS. 30-50k intervals will extend the life of the transmission. The spec. fluid is Toyota WS.
Bleeding the brakes is easy, I would also do 30-50k interval. All you need is a helper to bleed the brakes, you don't even have to remove the wheels, just jack up the car.
I agree, the single best thing you can do to have a worry free AT is to change the fluid every 30k miles but removing the wheels will make it a lot easier. :thumbsup:
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
587K members
Since 2001
