Originally Posted by Scott O'Kashan
If you use a tread depth gauge, you will find the center of the tire much more worn than the edges. Also, using inflation pressures that high will cause the tire to be very, very hard and not able to absorb/flex when it hits potholes etc., which can cause the tire to fail. A maximum inflation pressure of 44 psi cold is meant for high speed use to increase load carrying capacity, but it isn't the recommended air pressure.
-- B.F.Goodrich T/A Certified Tire Specialist
In other words, the tire can also wear out faster and negate any money saved on fuel.
