Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - NEWB car question in general....
View Single Post
Old 06-16-2004, 02:53 PM   #2 (permalink)
JSVH
JSVH's Avatar
View JSVH's Photo Gallery
Re: NEWB car question in general....
Originally posted by LoopyLady_1
1) Is the factory 6CD changer pretty good, or would I be better off getting one somewhere else?
Short Answer: go aftermarket, the 6 disk is the same as the stock unit, only it is $300 more and holds 5 more CDs (and the screen's back light can change colors ) . The stock head unit is good compared to others, but after market will always be better and cheaper.
2) How about the security system? If I get one installed somewhere else, does that screw with any warranties? Is it generally a better idea to get the factory system or just the opposite?
A few things: The tC has the key less entry buttons built into the key head (not a seperate fob). These may not work with an after market alarm, which means you have extra usless buttons on your key. The tC also has an engine immobilizer which makes it hard to steal in the first place, and makes adding remote start almost immpossible. A security system from Scion may be worth conisdering if you HAVE to have one.
3) If I want to get the 18" wheels, or the lip spoiler...better to do it from the start, or does it not make a difference?
It does not matter if you get those options right away or come back and get them put on in a year.
Previous Car: '93 Camry LE 4cyl
Current Car: Silver Scion tC 5-speed
JSVH is offline   Reply With Quote
