Here is DIY for those of you who might want some LEDs in the footwells
Before you start Disconnect your battery
Stuff I used:
*Thin flat head screwdriver
*3M double sided clear tape
*Blue LED strip
*wire crimpers
*black electrical tape
*phillips screwdriver
Start by removing the shift knob bracket by using the flat head wrapped in a rag to avoid scratching the paint. the piece just pops out
Remove the cup holder center panel. pop it out from each side using the flat head
Pull the piece out and you will see the connections to the SPORT AND TRACTION buttons, Unplug them.
For this part you have to plug your key in the ignition and turn it WITHOUT STARTING THE ENGINE. This is so you can move the shifter to (D) it will give you space to remove the next panel
keep using the flat head on all pieces. there are no screws holding the pieces.
Once you pull the piece out you will see the connectors for the USB and Cell phone charger. Unplug them
center panels removed
remove side lower foot panels Left and Right sides
there is a cover on the driver side hald by 2 phillips screws and a clip in the middle. This cover had to be removed so i can stick the LED strip
stick the LED strip on the metal part under the driver side and passenger side.
This is the 3M clear tape I used
run the wires through the back of the openings where you removed the lower side panels.
plug them to the cell charger and test for power
using the wire crimper peel off some insulation from both wires and splice the led wires.
*Once you have splice the wires use the electrical tape to seal them up.
some of you might use a different method but this one worked best for me.
Both sided lit up
Stuff I used:
*Blue LED strip
*wire crimpers
Both sided lit up
