I got it sorted out after another hour or so fussing with it and, most importantly because this helps as you know - cursing at it. The solenoid rod was stuck, and I was able to work it loose. Took it to a friend who does body and collision work and had him check it over and lube it up thoroughly and so far it is fine.
That anti-theft panel that covers the service hole is a HUGE pain, by the way. Getting the trim panel off the door while it was closed without destroying it was an even bigger pain.
Thanks for taking an interest in helping, Bill. It's appreciated.
Tim
