2007 Toyota Camry Hybrid Full Specs! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Toyota News
Toyota News News and discussion related to the Toyota family brand.
Old 03-01-2006, 12:33 AM   #1 (permalink)
TMS Prius Expert
Tideland Prius's Avatar
View Tideland Prius's Photo Gallery
USA 2007 Toyota Camry Hybrid Full Specs!
Taken from PriusChat.com
http://priuschat.com/index.php?act=ST&f=22&t=16719&st=0
Features
Standard features
P215/60R16 tires with 16-in alloy wheels
TPMS
Halogen lamps with auto on/off
DRLs
Heated dual color-keyed power outside mirrors
SKS
Cruise control
Maintenance indicator
Optitron meters with instant FE meter and multi-information display
JBL premium AM/FM/MP3 6-disc changer with bluetooth, 8 speakers, 440-watt output
homelink
Aux jack
Auto-dimming electrochromatic mirror with compass
Power windows with driver's express down
Dual zone automatic climate control with electric AC, pollen filter, rear vents and "plasmacluster"
Leather wrapped steering wheel and shift knob
Manual tilt and telescopic steering with audio/bluetooth/climate controls
Vehicle dynamics integrated management (VDIM)
Rear center headrests
60/40 folding rear seat
Chrome exhaust tip
Cargo net
Optional features
NAV with JBL premium AM/FM/MP3 with 4-disc changer, BT, 8 speakers and 440W output
Power tilt/slide moonroof with rear personal lamps
Leather-trimmed interior with driver and front-passenger heated seats
Unique styling cues
"Special" front grille
Blue tinted headlamp reflectors
Acoustic front windshield
LED taillamps
HSD badging
Miscellaneous cool stuff from the book
Electric power steering
Speedometer/multi-information display: provides trip info and power flow/FE data. instantaneous FE meter replaces tach
They didn't show a picture so i'm having a hard time picturing this, but "the meter's blue rings correspond to the average fuel consumption figure, the brightness of the rings change depending on the level of efficiency during the drive"
How cool does that sound.
And oh, oh, oh do i wish the Prius had this:
ECO HEAT/COOL BUTTON
"when engaged, the system allows the engine to shut down when stopped under a wider range of driving conditions for greater efficiency and reduced emissions. it does this by reducing heater and a/c output"
And NO FUEL BLADDER (same system as the HiHy- airtight metal fuel tank)
Specs
Engine
2.4L 4-cyl DOHC 16 valve with VVT-i
Bore and Stroke: 3.48x3.78 in
Compression ratio:12.5:1
HP: 147@ 6000 rpm
Torque: 138 lb ft@ 4400 rpm
Ignition: Toyota Direct Ignition
Fuel system: EFI
Fuel: Regular unleaded
Emissions control: AT-PZEV
Electric motor/generator/power storage
Permanent magnet synchronous motor
Electric motor power output: 108 kW @ 4500 rpm
Torque: 199 lb ft@ 0-2000 rpm
Battery type: Nickel-metal hydride (204 1.2 volt cells)
Nominal voltage 244.8
Transmission: ECVT
Capacity: 6.5 Ah
Battery peak HP rating: 45
Max voltage: 650
Hybrid system net horsepower: 192
Fuel economy
43/37, 40 combined (preliminary EPA estimate)
Zero to 60 in
8.9 seconds
Suspension
Front: independent macpherson strut with stabilizer bar
Rear: independent dual-link with stabilizer bar
Stabilizer bar front/rear: tube, 24.2/15.9 in
Brakes
Front- ventilated disc (hydraulic with power assist) and electronically controlled brake system with integrated regen system
Front diameter: 11.65 in
Rear- solid disc (hydraulic with power assist)
Rear diameter: 11.06 in
Parking: foot pedal
Swept area: front/rear 237.6/192.2 sq in
ABS: standard
Tires and wheels
Wheel size: 6.5x16 in
Material: alloy
Tire size: P215/60R16
Tire type: all-season steel radial
Spare: temporary
Steering
Type: electric power assist rack and pinion
Overall ratio 16.0:1
Turns: lock to lock 3.2
Turning circle: 36.1 ft
Exterior dimensions
Wheelbase: 109.3 in
Overall length: 189.2 in
Overall width: 71.7 in
Overall height: 57.5 in
Tread width: front/rear 62.0/61.6 in
Minimum ground clearance: 5.9 in
Drag coefficient .27
Interior dimensions
Headroom front/rear without moonroof: 38.8/37.8 in
with moonroof: 37.9/37.8 in
Leg room: 41.6/38.3 in
Shoulder room: 57.8/56.7 in
Hip room: 54.6/53.9 in
EPA passenger volume: 101.4 cu ft w/o moonroof
99.7 w/moonroof
EPA cargo volume: 10.7 cu ft
EPA class: midsize
Capacities
Engine oil: 4.3 qt
Fuel tank: 17.1 gal
Vehicle mass
3637 lb
Max towing weight: 1000 lb
Warranty
Comprehensive 3/36
Powertrain 5/60
Corrosion perforation 5/unlimited
Hybrid component 8/100 (15/150 in CA emissions states, except hybrid battery which is 10/150)
Safety
7 airbags standard: front, side, side curtain, driver's knee
Side impact door beams
3 point seat belts for all seats, emergency locking retractor on driver's belt, automatic/emergency locking retractor on all passenger belts, adjustable shoulder on front seat belts
ABS with electronic brake-force distribution brake assist
TPMS
VSC and TRAC replaced by VDIM
Childproof rear locks
DRLs
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
Tideland Prius is offline   Reply With Quote
Old 03-01-2006, 08:07 AM   #2 (permalink)
The Biggest comment Whore
Avalonman's Avatar
View Avalonman's Photo Gallery
Now I really want one!
Avalonman is offline   Reply With Quote
Old 03-01-2006, 12:23 PM   #3 (permalink)
Initiated as an Outlaw...
JayMax03's Avatar
View JayMax03's Photo Gallery
link doesn't work "G"
JayMax03 is offline   Reply With Quote
Old 03-01-2006, 12:39 PM   #4 (permalink)
TMS Prius Expert
PriusChat is down atm. The link just shows the source where I got this that's all.
Edit: It's back up.
Old 03-02-2006, 11:37 AM   #5 (permalink)
Official Acura Troll
View 02RSX90camry's Photo Gallery
wow, not bad, if i had the money, i'd think about buying one.
02RSX90camry is offline   Reply With Quote
Old 03-02-2006, 02:28 PM   #6 (permalink)
TMS Prius Expert
Depending the wheel, it may or may not affect mileage. There are quite a number of Prius owners running on 17" wheels. Their mileage loss ranged from 0 to 5mpg worst than what they got on the stock wheels.
Old 03-02-2006, 02:46 PM   #7 (permalink)
Newbie One Kanobi
ECHOKnight2000's Avatar
Gameroom cash: $577709
View ECHOKnight2000's Photo Gallery
You can't have one, you're the Avalonman!
U.S. media is a systematic censorship on free speech. They don't like what they hear they don't report. Don't want to upset the political and advertising sponsors. Its so corrupted. While they don't have to agree with certain views, its their job to report and let US decide.
ECHOKnight2000 is offline   Reply With Quote
Old 03-02-2006, 07:03 PM   #8 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
How much $$$
drunken_panda is offline   Reply With Quote
Old 03-02-2006, 07:07 PM   #9 (permalink)
Avalonman's Avatar
lol Camryman? Mr.07Camry
Old 03-03-2006, 01:43 AM   #10 (permalink)
TMS Prius Expert
16s are not that small... I guess I haven't seen the 07 Camry in real life. I mean 16s look nice on our 02 Camry but looks tiny on an IS250. Guess it depends on the bodystyle.
Go ahead, there's nothing wrong with making a hybrid sporty . I've seen a few HCHs with aftermarket rims. Heck, there's a Prius taxi here with 18" rims on low profile tyres and HID lights and foglights
Old 03-03-2006, 02:58 PM   #11 (permalink)
Buck Foston
Location: Connecticut, where you pay WAY too much for WAY too little
View AvalonMan96's Photo Gallery
Glad to see that leather seats are not standard, unlike on the Accord Hybrid where they are standard equipment only to jack up the price.
Toyota, again, has made the right move.
96 Avalon XLS--02 Tundra Access Cab SR5 V8 4WD
"Gen 2--The only Camry that matters"
AvalonMan96 is offline   Reply With Quote
Old 03-03-2006, 11:25 PM   #12 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
I have been comparing the Hybrid to the XLE 4 cylinder. I think the Hybrid will end up at $3,000-4,000 above the XLE.
XLE Feature Advantages
Price
35% bigger trunk
Reclining Back Seat w/ passthrough
Power Passenger Seat
Wood Trim Interior
Hybrid Feature Advantages
Smart Key
Better Fuel Economy
Moonroof not required - Save $ and better headroom
LED Tailights
Blue Tinted Headlights
No stabilty/Traction Control option required
Are there others of any consequence that I missed?
Old 03-04-2006, 04:02 AM   #13 (permalink)
TMS Prius Expert
Actually, the Hybrid has Lexus' VDIM system so it's standard that's why TRAC/VSC isn't listed.
Old 03-05-2006, 12:28 PM   #14 (permalink)
'07 XLE
Price
35% bigger trunk
Wood Trim Interior
Smart Key
Better Fuel Economy
LED Tailights
Hybrid also has a CVT instead of a 5 speed transmission that the XLE has. Also no fog lights listed or shown on Hybrid photos.
Old 03-06-2006, 07:41 PM   #15 (permalink)
Originally Posted by UfoZ
I just wish I knew when they were coming out... My dad really wants to get one.
I dont care if it might hurt the gas mileage, but the new Camrys are just screaming for a set of VIP style 19s!
Isn't it being released in May? I thougth the regular camry is being released in march, followed by the hybrid in may
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 09:42 PM
Personal Camry Websites - POST HERE Silver Streak Camry & Solara Lounge 193 08-03-2011 12:56 PM
Toyota Confirms Lexus LS, Camry for 2006 Detroit Auto Show EKam Toyota News 15 12-30-2005 10:30 AM
Toyota To Introduce All-New Camry for 2007 Tideland Prius Toyota News 4 11-27-2005 05:09 PM
Toyota's global strategy looks inward rolla-XRS Toyota News 7 11-29-2004 04:55 PM
