2008 Lexus IS-F 400HP V8 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > Toyota News
Toyota News News and discussion related to the Toyota family brand.
Old 02-16-2007, 09:17 PM   #1 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $529307
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Much of the development of the new IS-F took place at Fuji Speedway and the Higashi-Fuji Technical Center in Japan. The IS-F is based on the proven rear-wheel-drive Lexus IS, which is equipped with a double-wishbone front and multi-link rear suspension. As well as the IS performs, Lexus engineers demanded much more of the all-new IS-F. The result is a performance tuned 5.0-liter V8 engine, topped with specially engineered heads fed by a two-stage intake system, that produces 400-plus horsepower and more than 350 ft.-lbs. of torque. The all-new IS-F is equipped with engine-oil and transmission-fluid coolers for high-speed performance and a cylinder head-scavenging oil pump for high g-force driving.
The IS-F engine is mated to the world's first eight-speed direct sport-shift transmission. A new torque-converter lock-up control was developed that allows for a direct, crisp gear change through the constant lock-up of the torque converter in second through eighth gears. In Drive mode, the IS-F transmission performs with great smoothness, and the torque converter allows for great launch ability for fast standing-start acceleration that will register a zero-to-60 time in less than 4.9 seconds.
This unique transmission also features an advanced Manual mode. A pair of paddles located within a fingertip's reach behind the steering wheel enables the driver to make ultra-fast up-shift gear changes within a tenth of a second. Downshifts are accompanied by automated and incredibly precise throttle blips to match engine RPM to vehicle speed.
The impressive acceleration achieved by the IS-F requires it be equipped with heavy-duty Brembo brakes designed to the specifications of the Lexus engineering team. Huge, 14.2-inch cross-drilled front discs are gripped by rigid, powerful six-piston aluminum calipers, while 13.6-inch rear cross-drilled discs feature two-piston calipers. High-friction brake pads are equipped on all four wheels. The brakes are finished with the Lexus name displayed on the calipers, a first for a Lexus production vehicle.
The IS-F features custom-designed 19-inch forged alloy wheels as standard. The wheels were built to Lexus specifications by BBS and are surrounded by high-performance sport tires.
The attention to performance also extends to a modified suspension that lowers the entire car by more than a half-inch when compared to the base IS, and one full inch when compared to IS models equipped with 18-inch wheels. This specially modified suspension allows for an exciting and energetic drive, whether on a race track or the streets.
The IS-F features an all-new three-mode version of Lexus' Vehicle Dynamics Integrated Management (VDIM) system. In addition to the Normal mode, the new VDIM features a Sport mode that allows the driver to push the car even further before its braking-, throttle- and steering-control systems kick in. The third VDIM system mode is Off, which allows the driver to push the IS-F to its ultimate level of handling performance.
The attention to performance is complemented by modified styling cues that differentiate the IS-F from the standard IS. Lexus engineers provided the IS-F with a dual-exhaust system and quad-tail pipes, wider front fenders, and a larger grille and rear spoiler. Both the hood and lower intake were enlarged to accommodate and cool the V8 engine.
Like the exterior, the interior of the IS-F receives unique styling with aluminized composite trim and special surface treatments. The instrument panel includes an oil-temperature gauge and shift indicator-lights, while the "F" logo is showcased on the steering wheel and rear-center console.
In addition to the usual Lexus standards of comfort and convenience, the interior of the IS-F features specially shaped and trimmed seats, which hold the driver comfortably and securely in place. The special sport seats are available in black or a unique high-contrast white and black trim.
"The intent of creating the IS-F was not to be a competitor to other performance-sport sedans," said Carter. "Rather, the goal was to create a true performance sedan in a uniquely Lexus way-one that is totally authentic with a unique interpretation of raw driving thrill at all speeds and provides a whole new definition of 'usable power.'"
The IS-F will arrive at Lexus dealerships in early 2008.
* Powertrain
o Engine: 5.0 Liter V8
o Estimated Horsepower: More than 400
o Estimated Torque: More than 350 lb.-ft.
o Transmission: Eight-speed direct paddle sport shift gear box
* Brakes
o Large diameter cross-drilled discs
o Front/Rear: 14.2 inches/13.6 inches
o Opposed aluminum calipers
o Front/Rear: Six piston/two piston
* Wheels
o Forged aluminum wheels
o Front: 225/40R19 (19 x8)
o Rear: 255/35R19 (19 x 9)
* Performance
o 0-60 MPH Acceleration: Under 4.9 seconds
o Fuel Economy: TBD
o Emissions Rating: ULEV II
* Dimensions (inches)
o Overall Length: 183.5
o Overall Width: 71.5
o Overall Height: 55.5
o Wheelbase: 107.5
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 Neochromes - More on the way
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is online now   Reply With Quote
Old 02-16-2007, 09:26 PM   #2 (permalink)
What the Pho?
View SolaraTRD's Photo Gallery
Lol, I'll be first to mention... Doesn't the first image look photoshopped??? Or the paint just looks that crazy good? =P
~TN.com Unofficial AIM list~ Updated: 2-23-08
SolaraTRD is offline   Reply With Quote
Old 02-16-2007, 09:29 PM   #3 (permalink)
TN の がしょう
xpeed's Avatar
^ It's the actual color.
Old 02-16-2007, 11:53 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Very, very hot OEM wheels.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 02-17-2007, 12:00 AM   #5 (permalink)
View TRD-MX83's Photo Gallery
Okay let's drop the motor/tranny/brakes/wheels on to my car haha...
F*ck Just give me the damn car haha..
2004 Corolla S
2004 Matrix
1990 Cressida
03.5 G35 Sedan
TRD-MX83 is offline   Reply With Quote
Old 02-17-2007, 01:31 AM   #6 (permalink)
FJ nut
View RAV4EVR's Photo Gallery
love it........... pure ecstasy.
***** My love.... My dream.
RAV4EVR is offline   Reply With Quote
Old 02-17-2007, 02:15 AM   #7 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
the interior is just stunning...chrome paddle shifters, no bling overlooked lol
toyotaholic is offline   Reply With Quote
Old 02-17-2007, 03:56 AM   #8 (permalink)
View trxr's Photo Gallery
Front just looks awkard...I think the M3 will look better...
trxr is offline   Reply With Quote
Old 02-17-2007, 10:15 AM   #9 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
according to the spedo if there was no limiter it could race in nascar....lol!
what a sexy car.
nodrogkam is offline   Reply With Quote
Old 02-17-2007, 11:23 AM   #10 (permalink)
What the Pho?
Thumbs up in my book then. Looks intense!
Old 02-17-2007, 12:33 PM   #11 (permalink)
Streaker
Gameroom cash: $115659
View Streaker's Photo Gallery
Very nice car. My only gripe is those stacked exhaust pipes. They look gay!
2007 Camry SE Titanium Metallic V6: Muth signal mirrors, 18" TSW Mondello wheels, Crimestopper alarm/remote starter.
Streaker is offline   Reply With Quote
Old 02-17-2007, 12:48 PM   #12 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $261315
View TTercel's Photo Gallery
Damn looking at these pictures again this thing is pure sex. Although one thing I could do without is that weird side molding....looks like engine venting...iono
TTercel is offline   Reply With Quote
Old 02-17-2007, 04:55 PM   #13 (permalink)
Yota4Ever's Avatar
View Yota4Ever's Photo Gallery
Oh sweet, then it won't be wierd when I make love to that sexy IS-F
Yota4Ever is offline   Reply With Quote
Old 02-17-2007, 05:25 PM   #14 (permalink)
Streaker
I didn't mean it in that context. Some of you people are incorrigible!
Old 02-17-2007, 05:38 PM   #15 (permalink)
No avatar specified
Gameroom cash: $487290
View Camread's Photo Gallery
that explains the big buldge on the hood...
i think they're trying to make it look like a pipe organ
Camread is offline   Reply With Quote
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 12:30 PM
Lexus LF-A (Supra...reborn) Thundercat Toyota News 31 02-28-2007 11:51 PM
IS-F hot on-site shots (56K warning) BEI Toyota News 39 01-20-2007 12:12 PM
Lexus GS 450h: World’s First Hybrid Luxury Sedan journauto Toyota News 0 04-10-2006 11:14 AM
A Sexier Lexus CDNVITZ General Discussion 16 03-31-2004 04:15 PM
