Originally Posted by Gekko
I think the 1VD 4.5l V8 D-4D from the Land Cruiser will not appear in the Tundra. Altrough that engine can be tweaked enough to put out enough power to be competitive, I expect they use a large 4 or 6 cilinder truckdiesel engine from Hino.
I strongly doubt that, a 4 or 6 inline engine would be out of the question, they can`t comply with the emissions standards and they are *not* suited for a car, if you have seen these engines you would understand why..
Hino automotive diesel engines.
J05C
TI: 5,3L/I4 187hp@ 2500rpm / 5395lb-ft @ 1500rpm Weight 450kg
J08C
TI: 8,0L/I6 259hp@ 2500rpm / 550Lb-ft @ 1500rpm Weight 540kg
The rest of the lineup is not worth mentioning, they are way to heavy and bloated for a car.
I would be very supprised if something else than the new 1VD engine would show up in the Tundra.
